Short Shifter fitted! very short!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
shineydave
Post by shineydave » Mon May 08, 2006 6:05 pm
i've just modified my standard one after looking at clives kit. results are pretty much similar in that the shift distance is greatly reduced, much more precise, "switch like" would be a good analogy. took me about an hour and a half and cost nothing.
Dave
davs4
Post by davs4 » Mon May 08, 2006 6:14 pm
My Tanoga cost £80 delivered :jump_clap:
mikeyquattro
Post by mikeyquattro » Mon May 08, 2006 7:13 pm
davs4 wrote:My Tanoga cost £80 delivered :jump_clap:
Where from?
Tomorrow is another day
davs4
Post by davs4 » Mon May 08, 2006 7:59 pm
Audiworld classifieds :D Nice people across the pond.
ZeroK66
Post by ZeroK66 » Tue May 09, 2006 12:56 pm
Lucky sod :P
Shiney... take it this took some cutting & drilling?
shineydave
Post by shineydave » Wed May 10, 2006 7:07 pm
all i did was remove the lever en-mass, drill through the cast alloy piece at the bottom of the lever with a 3.0mm drill to give me a guide hole, that was about 15.0mm down from the existing bolt. then remove the bolt that attaches the alloy casting to the nylon shaft and open the hole in the nylon to accept the metal bush from the old hole. redrill the alloy casting to suite the bolt and re-assemble. once it was all back together i extended the existing thread for the gearknob by 30mm or so using an m12x1.5 pitch die and then lopped 30mm of the top, job done.
Dave
misternomer
Post by misternomer » Tue Oct 10, 2006 11:35 am
Don't flame me for saying this - but I love the standard shifter just the way it is. Maybe I should try a short shifter for a while. I just like floppy wristed gear changes with fingertips......
Reminds me a lot of my old Passat GL5. My wife has a A4 '96 V6 2.6 which I'd describe as being like a d1ck in a shirt tail. Big lazy changes. I love 'em.
2000 Avus Silver Avant:: MRC Custom Remap 310BHP
If you're not driving on the edge you're taking up too much space.
MarkB
Post by MarkB » Tue Oct 10, 2006 11:50 am
I have a short shifter wiating to go on but can't fault the standard shift so haven't got around to it yet...
Mark
s4-99
Post by s4-99 » Tue Oct 10, 2006 8:16 pm
@the 2 posts above: when you both have short shifter's fitted you will ask yourself 'why you didn't do it sooner' i was exactly the same until i got mine.....Excellent cheap mod. :thumbs:
Hmmm, its fast but is it fast enough!!!
Russ,greys4
Post by Russ,greys4 » Tue Oct 10, 2006 8:46 pm
mine arrived 2day from L.A 30quid off e-bay. looks good,shiney. will let u know if its any good. will fit it this weekend. :|
The lowriders gone! But still loved. Long live the 911-C2!!!
docurley
Post by docurley » Fri Oct 13, 2006 2:43 pm
Got mine on Wednesday and will be fitting it tonight, but as said I have found the reverse pin a lot larger than the hole so I will drill it out a little to allow it to fit. I may bring it to Audi International this Saturday and do it there as I will be there all day. :D .
shineydave
Post by shineydave » Sat Oct 14, 2006 12:12 pm
it's a bugger to drill without a vice, we struggled with a workmate but resorted to standing on the thing in the end, not very professional but we got there in the end
Dave
tdiquattro
Post by tdiquattro » Sat Oct 14, 2006 6:12 pm
I have the Tanoga but found it too long (the actual gear stick not the throw) so cut the thread another 15mm or so and lopped 10mm off the top, shortened the plastic under the leather gaiter by 10mm as well.
Miles better, I think the Tanoga product keeps the same gear stick length but shortens the throw, just the 10mm off the length mahes all the difference to the feel and action.
Btw - the bottom allen bolt adjustment is what causes the 1st 2nd gear selection probs, if it is not adjusted right (side to side, ie lean on the stick left or right as u tighten the bolt) then you can feel it trying to go slightly left as u push slowly against the gate into first, adjust it to help it that way and it will be fine.
hth Nige.
Nige'
2000 silver S4 Saloon
Users browsing this forum: No registered users and 140 guests
