Car feels twitchy on un-even surfaces?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
s4woody
RE: re:Car feels twitchy on un-even surfaces?
Post by s4woody » Wed Apr 19, 2006 12:34 am
i run 18,s and use 32psi all round..no tramming or pulling at speed or under braking..
GARTH ROAD MOT CENTRE LTD
020 83353032
saf
Post by saf » Wed Apr 19, 2006 1:31 am
My personal opinion. I think S4's ahould run on alloy size hats originally meant for the car 17 inch. Its best kept standard.
If I could afford 18's I would probably be a different opinion.
Since I read this post the other day, I too have felt the car making weird noised whilst cruising at normal speed (40mph). Feels like the car is making a rough sound when the tyres roll against the road. Or maybe you have just made me paranoid.
Oh well , off for another health check.
forget 4x4 mate. more like £x£
I just put two part worn pirelli tyres on the front of the car. 6ml tread each. Got them for £30 each so coudldnt say no to them. Waiting for back tyres to wear downa bit then going to put pilot sports all round.
By the way ZeroK66, whe you say tramming, do you mean when you out your foot down at high speeds you feel this and also when breaking from a high speed, or do you feel this constantly? Do you also feel like car has something losse about the drive? My friends car feels like that too. He said there was a change when he changed the tyres.
Did you check your tyre pressures already mate?
Also on the subject of tyres, does anyone know a good set of 4 tyres for the S4, mid priced. Set of thos pilot sports are bit pricy. How much the eagle F1's mate?
KayGee
Post by KayGee » Wed Apr 19, 2006 2:03 am
Tramming or tramlining meeans steering itself, following the road contours especially on motorways in the lorry tracks.
I run 36/38.
Mine felt terrible after fitting Clives H RS4 reps, but the tyre monkey had underinflated one of the rears, once back to correct pressure car feels planted again, checked them again at the weekend and definetly not leaking....
I've tried Fuldas (no) and Kumhos (17" and 18" feel good) on my S4 and driven a couple of other S4s shod with Pirelli (run away) and Eagle F1s (liked them).
tartan_rob
Post by tartan_rob » Wed Apr 19, 2006 12:27 pm
I run 18's with 235/40/18's all round. I am currently running 42psi all round as I do a lot of motorway driving but I'm not that happy. I may reduce pressure to 32 all round and see what happens.
2017 Kawasaki Z1000
2014 RS6
2014 S1
KayGee
Post by KayGee » Wed Apr 19, 2006 1:00 pm
Rob,
What width are your rims? 8 or 8.5?
Audi recommend 36/34, however backend didn't feel right to me, when I put my toolbox in the boot it felt much better, so I added a few psi to the rears and I prefer it like that, however most of my driving is done on a/b roads.
tartan_rob
Post by tartan_rob » Wed Apr 19, 2006 4:01 pm
I think they are 8 inch rims. I have dropped to 34 all round, have one trip up the motorway tomorrow, I'll increase the rear after as I'm back home again (and down the motorway) on Friday night. I must admit, I normally run tyres harder, it seems to stop them sideslipping under heavy or aggressive cornering and change of direction, however, outright grip may not be there.
2017 Kawasaki Z1000
2014 RS6
2014 S1
buzzard
Post by buzzard » Thu Apr 20, 2006 10:03 am
when i first had mine it was similar to yours.
alignment was the main answer. but it was the rear set up which was out not the front. so 4 wheel alignment is essential!!
got to say since the H&R arb's i have had a smile on me face round most of the bends that i go round unless im
carrying someting fragile!
S4 B5 long gone
S4 B8 Stage 2
Dippy
Post by Dippy » Thu Apr 20, 2006 5:30 pm
I run 38 front 36 rear. Any less and the handling is sloppy for me.
My original P6000s tramlined badly.
2001 Silver S4 Avant
BRETTCOLLINS
Post by BRETTCOLLINS » Thu Apr 20, 2006 5:48 pm
I have Uniroyal Rain sports 225/40/18's on my car. run 40 PSI front and 38 PSI rear.
Would check the rear ABR drop links for play. standard plastic units wear.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
s4woody
Post by s4woody » Thu Apr 20, 2006 6:19 pm
brett when you fit yours make sure the boots are filled with grease.. :thumbs:
020 83353032
