cold air intakes for rs4?
itaplikeabiatch
is there a BMC CAI for the rs4?
or rather is there any CAI for the rs4 that works?
i've been told different things by many people.
anyone?
anyone?
RE: cold air intakes for rs4?
Stay away from the BMC for the RS4, it flows less air than the stock airbox.
I have a BMC.... Not had any issues. Which block should I log?
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
003 for MAF and timing or 002 for MAF and injection period I think (S4). I have only
ever smelled an RS4.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
some1 told me Neuspeed or Nuespeed kit, he said it great. may b search it..
Interesting you should say that minhea,i'm running the standard airbox on my s3 and steve reckons it's more restrictive than his itg induction kit ,but have been told by another tuner that a oiled foam filter is a big no-no.
360bhp 342lb/tRE: cold air intakes for rs4?
@Ryan: I'm not getting into the tuner flame war where one says that what others use is cr@p or whatever. Sorry.
Just interested to know your thoughts on the stock airbox?Do you think it is a major restiction ,steve reckons you got good gains from using the itg kit. Power on the vf34/20 above 1.5bar boost seems to be really dictated by the compressor wheel and the amount of backpressure and heat generated.I will be ditching this turbo soon for a larger variety and wanted to know you thoughts on induction.Not interested in flame wars etc ,i have mentioned no names.
360bhp 342lb/tRe: RE: cold air intakes for rs4?
I am running a cold air intake put out by a guy in the states, X-1 intake, you can find him on the Audiworld boards. First mpression was a slightly beter throttle response but is also adds a tad more noise, more so on my car with a vented hood. Some folks don;t tlike the extra noise. It uses a oiled foam filter as well, ITG filter. It has not ruined a maf sensor yet after about 3K miles but I expect it will at some point. I am looking into a filter sold here in the US made by a firm called AEF or AFE, they sell a paper filter similar in design to the K&N but touts better flow and none of the oil issues associated with ruining maf sensors. FWIW I flowed the same gps @ 401gps peak on my setup that another person did with the same code and engine on a stock rs4 airbox with a sight mod to the box.Ryan_s3 wrote:Just interested to know your thoughts on the stock airbox?Do you think it is a major restiction ,steve reckons you got good gains from using the itg kit. Power on the vf34/20 above 1.5bar boost seems to be really dictated by the compressor wheel and the amount of backpressure and heat generated.I will be ditching this turbo soon for a larger variety and wanted to know you thoughts on induction.Not interested in flame wars etc ,i have mentioned no names.
hope this helps.
Blk 2001 Audi S4, full stage 3+, K04/RS6 hybrids, race cats, vented CF hood,Stasis Brakes and suspension, H-Sports, HRE 540 19x8.5. 450 on 93, 500 on 100 octane.
Yip, know someone that lost 10kw with one installed on an RS4. Naturally it was then removed.S2tuner wrote:Stay away from the BMC for the RS4, it flows less air than the stock airbox.
