Aux water pump replacement
Excellent post Simon! Thanks.
Clive
Re: Aux water pump replacement
SimonS4MTM wrote:and also sheltering from the rain
Exactly..well detailed .... not sure about the above though mate ...
cheers David
tartan_rob
Simon - I was being serious, it is not something I have even considered (or bothered) to look at....I'll need to get a torch out now...SimonS4MTM wrote:It leaks, as can be seen in the photo's. It looks like the barrier reef.
Or were you joking?
My post was more towards the pump actually not working as opposed to leaking. Is there any obvious way to tell?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
- SimonS4MTM
- Top Gear
Not sure about being able to tell if it is working, you can here it when you shut the engine off, but that does not necessarily mean it is pumping.Tartan_Rob wrote:My post was more towards the pump actually not working as opposed to leaking. Is there any obvious way to tell?
- SimonS4MTM
- Top Gear
Possibly, mine was leaking since before Christmas, I was topping it up every two weeks. Took me till last week to find where it was coming from.davs4 wrote:Could this be the reason my water level drops off from Max to below Min?
Best way to see it is looking from the right hand side, and underneath the back of the Y pipe.
a long screw driver or extension to your ear and resting on the pump should tell u if its working..well making a noise anyway..just cos they leak dnt mean they dnt pump..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
OH bugger sounds familiarSimonS4MTM wrote:Possibly, mine was leaking since before Christmas, I was topping it up every two weeks. Took me till last week to find where it was coming from.davs4 wrote:Could this be the reason my water level drops off from Max to below Min?
Just found this on AW new Spider hose p.n 078 103 235R.Unfortunately after I did mine!! Scroll down too 1/10/06. http://ctny.audiworld.com/mark/s4/maint ... gine_pull/
BrilliantBlack
Simon top post
I'm no mechanic, but I'm always up for DIY. Recently got my S4.. I'll let you guess the colour
Had good weather so this afternoon following your instructions etc for removal you were spot on m8
Mine didn't appear to be leaking but I thought about lack of sleep wondering what if hehe.. and plus with the missus watching crap on TV.. once the kids are in bed what better way to spend an evening.
Thx,
Nige
Thx,
Nige
- SimonS4MTM
- Top Gear
- SimonS4MTM
- Top Gear
