What is your peak MAF reading?
This is a good indication of power surely? What is yours (If Known) and what are your mods?
Mine is as per my signature - 262.
Cheers,
Leon
Cheers,
Leon
flossymeister
RE: What is your peak MAF reading?
hi Leon,
mine is fully standard and pulls 210
Tim
Tim
tartan_rob
Revo cars run an artificallially higher MAF reading due to them applying a multiplier high in the revs.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Thanks for that Tim - interesting benchmark!
Interesting what you say about Revo Tartan... hope others come back wtih some readings - K04 boys too
- confusionhunter
This is a good indication of power surely? have u got the 306 bhp chip in your car leon..? well 306bhp qouted by mrc i think? do u know the stats of the chip did the dealer tell u when u bought the car??
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Re: RE: What is your peak MAF reading?
Who told you this? I'm curious, as I've not seen anything which indicates that my MAF readings are high...Tartan_Rob wrote:Revo cars run an artificallially higher MAF reading due to them applying a multiplier high in the revs.
http://badger.ing.me.uk/vagcomlog.html
is a log from last year, since doing that have made a couple of changes (air filter, fuel, and also boost + timing settings on the SPS), which have reduced my FATs time, and increased my maf readings from ~256g/s, to ~264g/s
I was told by the guys at Revo (Mitchell + Kev) when there (my car was used to help iron out an issue which sometimes occured on S4s), that as a result of the revised map using less boost than some other tuners, and more timing, that I could easily end up with slightly lower MAF readings when comparing logs with others...
Perhaps they removed this multiplier when they revised the remaps?
Returning to topic, 264-265g/s is what I'm normally seeing with:
Revo, Full milltek, green panel filter + drilled airbox.
thanks
Andy
tartan_rob
RE: Re: RE: What is your peak MAF reading?
Andy - I was shown the map of the revo code and there was a multiplier at high revs. I think my car was reading 265 odd with revo and running same boost and similiar timing, it was down to about 250 odd. No big deal, its how they tune their chips I suppose.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
- SimonS4MTM
- Top Gear
250 peak MAF, with MTM and Miltek single
ah ok, fair enough.
The dealer advertised the car is 310BHP - given the ex-owner worked for that dealership I can only assume that this is correctish. With a reading of 257 Mihnea recons I was getting between 305&310HP - so about right.s4woody wrote:This is a good indication of power surely? have u got the 306 bhp chip in your car leon..? well 306bhp qouted by mrc i think? do u know the stats of the chip did the dealer tell u when u bought the car??
MTM quote 306BHP for their chip + an exhaust - I would expect 310ish. With the cats gutted I was hoping for something closer to 330ish
Of course MAF reading is not the be all and end all of estimated power. What the cars map/chip does with the timing can make a fair difference to what power you see from that amount of air. Agressive timing could see another 10BHP+ from the same amount of air vs a conservative map/chip's timing.
Simon - you effectively have the same mods my car did. Interesting. Have to get in touch if we are ever near one another geographically.
- SimonS4MTM
- Top Gear
Sure will, what part of the country are you in?
- SimonS4MTM
- Top Gear
Ah, Devon
Users browsing this forum: No registered users and 220 guests
