Tyre load rating dvice for those gone from 19 to 20
Hey guys
My B7 OEM tyres were 96Y rated on the 255/35/19 however now going up to 20" wheels, I can't seem to find tyres higher than 92Y on 255/30/20
Or best I've found on 265/30/20 are 94Y
What have those you of you who have gone from 19" to 20" opted for?
Nils
Nils
Instagram : n_i_l_s
Re: Tyre load rating dvice for those gone from 19 to 20
I 'think' the I've run a Yokohama 265/35/r20 with a 99Y. Quite a rounded tyre so they fit ok, if memory serves me. Best try some test fit/measuring.
I've also tracked GY F1s 255/35/r20 94Y stretched on 20x9.5s - they were actually really good and my car is probably heavier than yours.
I'm hoping to go 255/30/20 on my 9j wheels so that's good to hear, I don't track mine either
Cheers Bam
Cheers Bam
Instagram : n_i_l_s
- geordie jay
- 5th Gear
I run 92y on my 20".......no issues
Had the exact same dilemma on my c6 when i switched 19 to 20's. I'm running 255/30/20 on a 92y for a year now with no issues, my c6 must be way heavier so can't see a problem
I thought the C6 ran 275 section, why you running 255s?
I'm running 92Y XL on mine.
I'm running 265/30/20 94Y for two reasons, like you I can only find 92Y tyre load rating on 255/30 tyres and the 265/30s are a little closer at 94Y. Secondly, the speedometer reads more accurate with 265/30s.
Mercedes E-Coupe 350CDi
Coz its my daily oil burnerbam_bam wrote:I thought the C6 ran 275 section, why you running 255s?
Ahhh.
Bam, I think he is saying it's not an RS6 .
Yeah. Hence my "ahhh". It's funny how we all just assume any post is referring to an RS.
My last set of tyres were 265/30/20and 94Y like you. But why do you say they are more accurate? 255/30/20 will read exactly the same as OEM tyres but 265 will introduce a slight error due to the size difference. Are you saying the OEM tyres are not the most accurate size?nij wrote:I'm running 265/30/20 94Y for two reasons, like you I can only find 92Y tyre load rating on 255/30 tyres and the 265/30s are a little closer at 94Y. Secondly, the speedometer reads more accurate with 265/30s.
I know the gearing will be slightly out, but what I ment was more accurate to the true speed you're travelling. Almost all speedos under read by about 10%, therefore when it reads 30mph, you're only really travelling at about 27mph. If you ever pass one of those "Your Speed" signs, you'll know what I mean. You could also check your Sat Nav speed in "Engineer Mode" in your RNS-E, which is more accurate and it isn't affected by tyre wear.MikeFish wrote:My last set of tyres were 265/30/20and 94Y like you. But why do you say they are more accurate? 255/30/20 will read exactly the same as OEM tyres but 265 will introduce a slight error due to the size difference. Are you saying the OEM tyres are not the most accurate size?nij wrote:I'm running 265/30/20 94Y for two reasons, like you I can only find 92Y tyre load rating on 255/30 tyres and the 265/30s are a little closer at 94Y. Secondly, the speedometer reads more accurate with 265/30s.
- geordie jay
- 5th Gear
haha when I pass those signs at 30mph it says 30mph???? sure your alloys aren't square fellanij wrote:I know the gearing will be slightly out, but what I ment was more accurate to the true speed you're travelling. Almost all speedos under read by about 10%, therefore when it reads 30mph, you're only really travelling at about 27mph. If you ever pass one of those "Your Speed" signs, you'll know what I mean. You could also check your Sat Nav speed in "Engineer Mode" in your RNS-E, which is more accurate and it isn't affected by tyre wear.MikeFish wrote:My last set of tyres were 265/30/20and 94Y like you. But why do you say they are more accurate? 255/30/20 will read exactly the same as OEM tyres but 265 will introduce a slight error due to the size difference. Are you saying the OEM tyres are not the most accurate size?nij wrote:I'm running 265/30/20 94Y for two reasons, like you I can only find 92Y tyre load rating on 255/30 tyres and the 265/30s are a little closer at 94Y. Secondly, the speedometer reads more accurate with 265/30s.
Users browsing this forum: No registered users and 133 guests
