Suspension Again
Suspension Again
I had the whole of my suspension replaced under warranty; all 4 shocks etc, now found the front 2 are leaking AGAIN and the whole 4 need to be replaced AGAIN. Anyone else had this problem?
Is there a problem with the shocks I don’t know about?
Yes, it's actually 5 years and 75k miles, and applies, as a minimum, to all UK-supplied RS4s.
I have the 'new' parts, having now had 10 shocks i think in total. They appear to be OK so far, and i am becoming convinced that their longevity is related at least partly to the quality of the installation process, which is a bit complicated.
I believe it is, on the fronts, a new sealing design and on the rears a new gaiter (or even addition of a gaiter) which should stop crud getting to the (vulnerable obviously) seal.
You would have thought that the 100-year old technology of sealing a shaft was pretty well landed by now. After all, it's not the complexity of the DRC bit that seems to be failing, it's simply the stem seal.
