What warranty work have you had done?
stenning
Post by stenning » Fri May 15, 2009 1:06 pm
I am trying to compile a list of potential warranty issues on the B7, would it be possible to post warranty work you have had done here and I will try and compile a full list at the end.
Thanks in advance for your help!
PetrolDave
RE: What warranty work have you had done?
Post by PetrolDave » Fri May 15, 2009 1:26 pm
0080 SW upgrade - that's it.
Andyuk911
Re: RE: What warranty work have you had done?
Post by Andyuk911 » Fri May 15, 2009 1:42 pm
PetrolDave wrote:0080 SW upgrade - that's it.
You fib .. what about the Nav disc for TMC .... :lol:
RS4 Avant - Sold Aug 2009
Dom81
RE: Re: RE: What warranty work have you had done?
Post by Dom81 » Fri May 15, 2009 1:54 pm
SW upgrades (which might be warranty work, but certainly not an "issue"), a squeaky seat and DRC
No doubt most people have had something done - unique to them (or a small group) in many cases - and I'm not exactly sure how a list of these would help
Isn't it a bit like asking who's been to the doctors, and what for? You'd never leave the house...
2007 Daytona RS4 Avant
P_G
Post by P_G » Fri May 15, 2009 1:56 pm
I thnk it is safe to say DRC and brake discs are the two most notable ones. I have also heard of clutch / pipe but touch wood have never had anything like this done on mine.
Nothing else for me.
stenning
Post by stenning » Fri May 15, 2009 2:14 pm
Thanks, what was the issue with brake discs?
In terms of "Isn't it a bit like asking who's been to the doctors, and what for? You'd never leave the house..." I think the use will be for owners to check before the cars goes out of warranty, the same as life insurance companies ask for a medical before providing cover, they check the basics not every possible medical problem.
chrissyr32
Post by chrissyr32 » Fri May 15, 2009 3:36 pm
Where do you want me to start???
Faulty low break pad sensor
Knackered valve in drivers seat to inflate bolsters
Creaking interior trim "A" pillars.
Corrosion on alumimnuim boot strip
Failed coil pack cylinder 8.
Fuel sensor recall
Battery holder recall.
Loose drivers door handle exterior.
ALL fixed under warranty though never cost me a penny apart from fuel to and from dealers.
BUT i still love this car!!!!!
PetrolDave
Post by PetrolDave » Fri May 15, 2009 4:06 pm
That wasn't a warranty issue for me - I got hold of the disc from contacts in Europe three months before it was available in the UK.
klauster
Post by klauster » Fri May 15, 2009 4:20 pm
DRC obviously
front brake disks
engine mounts
couple of recalls - nothing major
Still hoping to get some work done through the warranty at the moment - ECU update for starters...
Boots
Post by Boots » Fri May 15, 2009 7:31 pm
DRC - 2 shock absorbers
Battery holder
New front seat clips
Loose trim in boot
New engine
Oli
Post by Oli » Fri May 15, 2009 7:42 pm
DRC - All
Battery tray
Wheel bearing
MAF - Ongoing........
P_G
Post by P_G » Fri May 15, 2009 7:43 pm
Blimey, a new engine is a new one! What did you do to the old one?
Dom81
Post by Dom81 » Fri May 15, 2009 7:49 pm
Love the way that it's last on the list, after a bit of trim!
rjkflyer
Post by rjkflyer » Fri May 15, 2009 8:42 pm
RECALL
Fuel sensor recall
ADVISORY
Battery tray advisory (crack in floor)
Power steering fluid change advisory (noisy pump)
0090 sw advisory (major improvement to cold running)
TMC sw update (cos it should work!)
FAILURES
One adaptive xenon replaced on day two of ownership
At least 8 or 10 shock absorbers (now seems OK)
2 coil packs on same cylinder (suspect faulty plug as fault came up and recurred within a month, then gone with new plugs)
Oli
Post by Oli » Fri May 15, 2009 8:43 pm
Rik, the PAS fluid change - was that to cure the groan on lock?
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 147 guests
