Hmmm ... still not ideal; should be between 210 and 220g/s for a healthy stock S4.Just fitted my new MAF.... max reading now 194
What is your peak MAF reading?
RE: Re: RE: Re: RE: Re: RE: What is your peak MAF reading?
Deus ex machina
Possible boost leak somewhere ?
Check my post in the Vag-com section, i got a new fault come up
Also, whats the std boost in mbar ? My max reading was 1540
- shineydave
i thinks it's 0.8bar so as Vag-com records the ambient pressure of the atmosphere as well it should read around 1800mbar for a standard car
- Top Gear
My MAF
Umm.. interesting stuff.
I took a max MAF on mine of 233.5
Mine is standard, AFAIK and according to QST who serviced it.
So is my MAF screwy?
But what's the % range for power as standard on this car?
If 10% then just a good one.
My boost readings all standard, requested 0.8 above ambient, acheived 0.8...
Quess I need to FATS test too.
Will try tomorrow.
Will try tomorrow.
So whats that mean ? I just fitted brand new MAF. Boost is normal. No fault codesDavidT wrote:It's too high mate. Standard car should flow 213 !
I got some FATS here... http://www.rs246.com/index.php?name=PNp ... ic&t=62874
Post in this one http://www.rs246.com/index.php?name=PNp ... ic&t=62874DavidT wrote:Belongs in another thread really.
Got 227.75 today on a std car as far as I know.
Also got peak boost of .9 bar and peak requested (never seen before I might add) of 1.02 bar!
That was on my first run before I guess heat soak from hanging around for a clear road took over.
Still manged 223 and peak boost of .83 bar iirc (laptop off at the mo).
I wonder if the current atmospheric conditions are having some effect on air pressure.
- GrimReaper
275 from my KO3's
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
