ABS Pump Control Unit
MalcolmSu
Post by MalcolmSu » Mon Apr 04, 2016 7:54 pm
Excuse my lack of technical knowledge here...
I'd been told i needed to replace my ABS Pump Control Unit as if it's a thing, but the more I read about these it's actually several things? Am i correct in saying it's more likely that it's the Control Unit that's failed and not the ABS Pump? And in that case is it not possible to remove the (Electronic) Control Unit by itself for repair or replacement - just means there would be no ABS control? Or is it always better to repair or replace these two things as a unit?
BTW the above is all academic as I've now purchased a s/h ABS Pump (and?) Contol Unit and await delivery. Just interested...
Re: ABS Pump Control Unit
Post by Shoppinit » Tue Apr 05, 2016 10:56 am
They are a single unit but can be persuaded to separate. I'd be interested to know what fails in them.
rsmotors
Post by rsmotors » Tue Apr 05, 2016 9:02 pm
yes me too as its either the unit failure or a wiring break, i have tried 2x used units and still cannot communicate with the abs brain via Vag Com,,, :boohoo:
MalcolmSu
Post by MalcolmSu » Tue Apr 05, 2016 9:06 pm
that's not good news... Not expecting mine until next week, but will report back.
monoi
Post by monoi » Fri Apr 08, 2016 10:51 pm
The fault on mine was some of the very fine wires in the control unit had broken. Not repairable.
Jultsu
Post by Jultsu » Sat Apr 09, 2016 9:59 am
monoi wrote:The fault on mine was some of the very fine wires in the control unit had broken. Not repairable.
Yes they are.
Post by Shoppinit » Sat Apr 09, 2016 10:05 am
Told.
rsmotors
Post by rsmotors » Sat Apr 09, 2016 5:37 pm
Well it appears that mine is refusing to be recoded,,,this was after my original unit was repaired , and then still refused to be talked to by the vag,
at the moment awaiting some other input from a higher source , will keep you informed , apart from the the car is stunning , forgot how quick it is,
rsmotors
Post by rsmotors » Wed Apr 13, 2016 8:09 pm
right so mine is going back to the dealer for a date with the mother hub, so it can be connected to the all seeing dealer , and then [no doubt ] the fun shall begin , i feel i am heading towards a new abs module :assflash: this will be how it feels no doubt,,
rsmotors
Post by rsmotors » Sat Apr 23, 2016 11:47 am
Good news , all coded at the local dealer and its sorted , seems that if buying a used brain it needs to be recoded to the recipient vehicle using the original abs brains code, which could not be retrieved as comms to the unit was part of the problem, so i will be taking a note of all the control units for any further reference.
Then once this was sorted the ac began working again, .
picking it up this afternoon with a new ticket , :jump_clap:
Post by Shoppinit » Sat Apr 23, 2016 12:20 pm
Yay!
Users browsing this forum: Google Adsense [Bot] and 244 guests
