ABS light on
bazsroa
ABS light on
Post by bazsroa » Mon Mar 21, 2011 2:36 pm
Hi chaps, Got a RS6 avant on a 04 plate ABS light keeps coming on intermittently, had a mate put his code reader on it and found trouble code c00287 rear right wheel speed sensor open circuit or short to ground, ive changed the sensor and still no joy ive had the wiring checked all ok, what i want to ask has anyone had problems with the control unit.
scooby-tc
Re: ABS light on
Post by scooby-tc » Mon Mar 21, 2011 3:27 pm
I had the control unit replaced on mine after it was showing the same symptoms as you and was verified as a faulty unit by Audi.It was replaced under warranty for £1300 or thereabouts.It might just be the brake switch which also causes the abs light to come on and that is significantly cheaper
2003 RS6 Avant (NOW SOLD)
Golfather
Re: ABS light on
Post by Golfather » Mon Mar 21, 2011 5:44 pm
Try cleaning the connector at the ECU, and checking the continuity of the loom for that side using the diagrams on ELSA. I still think it would be a wiring issue if it is only coming up for one sensor.
RS6Steve
Re: ABS light on
Post by RS6Steve » Mon Mar 21, 2011 6:52 pm
Check the wiring out before you do anything! Like golf says may just be a lose connection.
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
philroach
Re: ABS light on
Post by philroach » Mon Mar 21, 2011 9:03 pm
just had new abs module , fitted under warranty , all warning lights on , Audi diagnosis , Warranty Direct payout , eventually
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
bazsroa
Re: ABS light on
Post by bazsroa » Tue Mar 22, 2011 7:24 pm
Hi guys thanks for the reply, i took on the job of testing the wires my self yesterday and all reading good, road tested with a diagnostic tester to carry out a data list of the sensors all working ok, so im thinking its possibly the ecu, any thoughts before i get it replaced.
WAFWOTTBI
Re: ABS light on
Post by WAFWOTTBI » Sat Mar 26, 2011 6:50 pm
When my abs light was coming on,turned out to be brake pedal switch,as also sends feed to abs system so i was told,20 pound fix,been fine for 6 months,touch wood...WAFFY... :blackrs4:
RS 6 Avant,
Ebony black mettallic,03 plate,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Re: ABS light on
Post by Shoppinit » Tue Mar 29, 2011 10:17 am
Did you sort this?
bazsroa
Re: ABS light on
Post by bazsroa » Tue Mar 29, 2011 4:34 pm
No not yet, trying to get time but juggling a misses and three kids is exhausting, but i will defo crack on with it soon.
Users browsing this forum: srichards and 260 guests
