New Front Control Arms
Prawn
Post by Prawn » Thu Jan 20, 2005 6:09 pm
Arrived today, should be in place for Silverstone.
Will be interesting to see what the increased castor and camber does.
Prawn
johnRS4
RE: New Front Control Arms
Post by johnRS4 » Thu Jan 20, 2005 7:55 pm
Nice one :nodder:
John
JS
johneroberts
Post by johneroberts » Thu Jan 20, 2005 11:06 pm
is that especially made for the RS4 or is it the S4 one?
jr
Driving is believing
RS246 Founder
Prawn
Post by Prawn » Fri Jan 21, 2005 9:57 am
These were made initially for the S4/RS4 hybrid that Stasis run in the WSC series in the USA.
Now available (if you push) for sale.
Should all fit ok, will find out next week !
Prawn
JonnyX
Post by JonnyX » Fri Jan 21, 2005 10:41 am
Stasis have some sweet, sweet items. Are you tempted by the lsd and 4:1 centre diff?
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Prawn
Post by Prawn » Fri Jan 21, 2005 12:31 pm
Not yet but you never know.
I think I would go for the rear control arms next, will see how the front ones do first.
Prawn
BW
Post by BW » Sat Jan 22, 2005 1:10 pm
Prawn,
You really have to get the LSD replaced, it is worth more than saying, no doubt as much as the ohlins you installed.
Ben
bem_ho
Post by bem_ho » Wed Jan 26, 2005 3:59 pm
I second that!! Both Torsen and rear LSD!! You should also consider to have a 22mm rear sway bar to go with it!!
kiwi_mtm
Post by kiwi_mtm » Mon Jan 31, 2005 4:01 am
Excuse my ignorance, but whats the benefit of these aftermarket control arms ?
Prawn
Post by Prawn » Mon Jan 31, 2005 9:54 am
Allow you to adjust camber which is non adjustable as std, except as a function of ride height
Ans also allow you to adjust castor, no adjustment as std.
Prawn
flashyg
Post by flashyg » Thu Feb 03, 2005 10:38 pm
How long did the Job take to fit these,
Did other arms have to come off to get them in.
Thanks.
G
Prawn
Post by Prawn » Fri Feb 04, 2005 10:02 am
OK, got these fitted Wenesday.
Took about 3 hours to get the old control arms off as the 12mm bolts are a PIA to get out as they are usually siezed in, once the bolts are out it takes about 30 mins to remove the old arms and refit the new ones.
Then its a case of trial and error to get the caster and camber set up, this took us about 2 hours to get to a resonable setting.
I am planning to get a full alignment done at Austec Racing in the next 2 weeks to fully check the settings but currently I am running :
6 Deg Castor (4.5 std)
-1.75 Deg Camber
0 toe
The car now feels much more 'pointy' the turn in is significantly improved and the front end now reminds me very much of my old Evo 5
Really need to get it on track to feel if the increased camber has generated the extra grip I am looking for.
Will report back after Silverstone.
Prawn
flashyg
Post by flashyg » Fri Feb 04, 2005 1:37 pm
Thanks for the info. Keep us informed.
G
