LOW FAT SPREAD
jimbo1234567
- 5th Gear
LOW FAT SPREAD
thought it was about time i did a few pics and spec..
engine..
rs4 engine
itg air filter
cut out airbox
2.4 heads (standard)
front mount intercooler
710n,s
1.0 comp dropping gaskets
std bottom end
phelonic spacers
ceramic coated mtm ex manifolds
straight rs6 turbos
heat wrapped milltek catless downpipes 2.25"
dual milltek exhaust
tanoga flywheel
uprated helix clutch
side mounted mocal oil cooler
welded up intake-throttle body pipes
boost is about 25 tapering to 22 psi
27 degrees of advance on the timing
the maf was showing 430 gs
9.5x19 mtm wheels
275 30 19 goodyear assymetrics
esp 10mm spacers
h+r fat arbs with mrc strenghening brackets
tanoga short shifter
awe dts bar
dash mounted boost gauge
carbon steering wheel
b7 brakes all round
20 gb phatnoise
laser park pro
roofrack
towbar
tracker
engine..
rs4 engine
itg air filter
cut out airbox
710n,s
std bottom end
phelonic spacers
straight rs6 turbos
tanoga flywheel
9.5x19 mtm wheels
esp 10mm spacers
awe dts bar
b7 brakes all round
20 gb phatnoise
laser park pro
roofrack
towbar
tracker
665 bhp + 586 lbft...
jimbo1234567
- 5th Gear
RE: LOW FAT SPREAD
forgot to mention .. a minhea map
RE: LOW FAT SPREAD
looks great jimbo - saw the car at Unit20 a while back getting some TLC good to see you up and running again.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
RE: LOW FAT SPREAD
Hubba hubba.
Great spec Jimbo
If you get upto Scotland anytime, give us a shout
You forgot to mention the SAI delete mod as well
Great spec Jimbo
RE: LOW FAT SPREAD
what a lovely looking motor mate!!! awesome!! power must be insane!!
jimbo1234567
- 5th Gear
Re: RE: LOW FAT SPREAD
FazS3 wrote:what a lovely looking motor mate!!! awesome!! power must be insane!!
needs more
RE: Re: RE: LOW FAT SPREAD
Looks very nice and a top spec. But I was wondering why only 502hp (ONLY he says!!!).
550 Lbft seems a good figure - is this a larger increase over a 460 MTM car in comparison with the HP figures.
I've no idea what torque mine is but this is the key factor. Im guessing it would give a 460 car a good whooping...
I was under the impression that a FMIC could yield 30hp, giving around 490.
yours has the RS6 blowers and other nice little bits and bobs that i presume add HP or keep temps down - so why only 502.
Dont be offended! Im just quite surprised at such small increases and probable expense to eeek out those extra neddys after the initial unleashing via remap and breathing.
OR is that at the WHEELS...in which case - mint!
Misano RS4 (B5), MRC Custom Map , Quick shift, Milltek Exhaust and Downpipes, B7 Front Brakes, B7 19's
I'm not sure... most RR at similar power levels. And anyway mine was MTM, now MRC remap. Doug indicated it was good for around 460. Never had it rolled though, but even then there are differences between the rollers out there....
Fair point though! I have some rollers about 1 minute from where I live - just never got round to a power run!!
jimbo1234567
- 5th Gear
my car makes arelitively low bhp because the airflow is restricted due to 3 things.
1 intake pipes. still using std k04 intakes as i couldnt get hold of the mrc ones
2 turbo inlets. rs6 turbos use the same size inlet as a k04... mrc usually put a larger inlet on the turbo for more flow
3 downpipes. im using the milltek 2.25" ones instead of the 3"ones that mrc use.
on a turbo car when its being mapped theres always a trade off between boost /timing. more boost =more bhp but that also means you have to have good airflow. if you want torque then you back off the boost and increase the timing instead. looking at the dyno graph lucas posted in another thread of their 592 bhp car my car makes more torque. another thing to add is the wrc rally cars have air intake restrictors to cap the bhp but they make shed loads of torque. hope this helps. jim
jimbo1234567
- 5th Gear
jimbo1234567
- 5th Gear
the itg filter is just a straight panel replacement and the hole is at the front of the airbox so i dont think anymore noise comes from there although the car does sound like a train.
Users browsing this forum: No registered users and 83 guests
