Tyre pressure warning
Norrs2
Post by Norrs2 » Thu Mar 15, 2012 8:35 pm
Can anyone tell me if you can disable the tyre pressure warning system using Vagcom?
Thanks!
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
sumdy
Re: Tyre pressure warning
Post by sumdy » Thu Mar 15, 2012 8:57 pm
Pretty sure it can,someone will come along and confirm.
neckarsulm
Post by neckarsulm » Thu Mar 15, 2012 9:06 pm
It can be done, I have never done it and would never do it to my own car.
PetrolDave
Post by PetrolDave » Fri Mar 16, 2012 6:41 pm
Norrs2 wrote:Can anyone tell me if you can disable the tyre pressure warning system using vagcom?
Thanks!
You can disable the warnings appearing on the DIS, but you don't need VCDS to do that as you can do that from the DIS menu.
You can't disable the diagnostics on the TPMS itself though, even with VCDS.
guffy
Post by guffy » Fri Mar 16, 2012 7:36 pm
Thanks!
Not sure you can disable the warning using the DIS when one of the batteries has filed, which is the most common reason for wanting to disable the system?
The following will disable the TPMS vis VCDS:
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
PetrolDave
Post by PetrolDave » Fri Mar 16, 2012 7:45 pm
guffy wrote:Not sure you can disable the warning using the DIS when one of the batteries has failed
That's a diagnostics message, not a low or very low tyre pressure warning - so you can't disable that using the DIS (and I didn't say you could disable diagnostics, only warnings).
AdrianD
Post by AdrianD » Fri Mar 16, 2012 9:58 pm
Out of interest why would you want to? I had a flat last week on the rear and am positive the early warning saved damage to my alloy wheel...
2010 911 Turbo PDK.
Gone but not forgotten... Sprint Blue B7 RS4 with all the toys :)
20" AG M310's | TTS Supercharged | MRC Stage 3 | Sach's Clutch | Lightened / balanced flywheel | High Pressure Fuel Pumps | KW V3's Coilovers | De-Cat + Valved Milltek | DeCoked | Launch Control | Flat Shift | Cold Air Feed Induction.
Norrs2
Post by Norrs2 » Mon Mar 19, 2012 12:16 pm
Thanks for all the replies gents!
It's not my car, I was asking on behalve of a mate. Warning was coming up after having his wheels refurbed, even though there was ample pressure there. Maybe only needs a reset then.
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
PetrolDave
Post by PetrolDave » Mon Mar 19, 2012 6:24 pm
Norrs2 wrote:Warning was coming up after having his wheels refurbed, even though there was ample pressure there. Maybe only needs a reset then.
Yes, it needs a reset. Almost certainly the wheels are on in different positions and that will cause a red warning. Just turn the ignition on, but don't start the engine, and you'll be able to do a TPMS "wheel change" on the DIS and it should go away.
Users browsing this forum: No registered users and 548 guests
