Tyre pressure warning
Can anyone tell me if you can disable the tyre pressure warning system using Vagcom?
Thanks!
Thanks!
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Re: Tyre pressure warning
Pretty sure it can,someone will come along and confirm.
neckarsulm
It can be done, I have never done it and would never do it to my own car.
- PetrolDave
You can disable the warnings appearing on the DIS, but you don't need VCDS to do that as you can do that from the DIS menu.Norrs2 wrote:Can anyone tell me if you can disable the tyre pressure warning system using vagcom?
Thanks!
You can't disable the diagnostics on the TPMS itself though, even with VCDS.
PetrolDave wrote:You can disable the warnings appearing on the DIS, but you don't need VCDS to do that as you can do that from the DIS menu.Norrs2 wrote:Can anyone tell me if you can disable the tyre pressure warning system using vagcom?
Thanks!
Not sure you can disable the warning using the DIS when one of the batteries has filed, which is the most common reason for wanting to disable the system?
The following will disable the TPMS vis VCDS:
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
- PetrolDave
That's a diagnostics message, not a low or very low tyre pressure warning - so you can't disable that using the DIS (and I didn't say you could disable diagnostics, only warnings).guffy wrote:Not sure you can disable the warning using the DIS when one of the batteries has failed
Out of interest why would you want to? I had a flat last week on the rear and am positive the early warning saved damage to my alloy wheel...
2010 911 Turbo PDK.
Gone but not forgotten... Sprint Blue B7 RS4 with all the toys
20" AG M310's | TTS Supercharged | MRC Stage 3 | Sach's Clutch | Lightened / balanced flywheel | High Pressure Fuel Pumps | KW V3's Coilovers | De-Cat + Valved Milltek | DeCoked | Launch Control | Flat Shift | Cold Air Feed Induction.
Thanks for all the replies gents!
It's not my car, I was asking on behalve of a mate. Warning was coming up after having his wheels refurbed, even though there was ample pressure there. Maybe only needs a reset then.
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
- PetrolDave
Yes, it needs a reset. Almost certainly the wheels are on in different positions and that will cause a red warning. Just turn the ignition on, but don't start the engine, and you'll be able to do a TPMS "wheel change" on the DIS and it should go away.Norrs2 wrote:Warning was coming up after having his wheels refurbed, even though there was ample pressure there. Maybe only needs a reset then.
