Xenon flickering
Xenon flickering
Hi all,
Just picked up my b7 s4 couple of weeks ago, the xenon headlight start flickering, went to Audi for servicing and checked the problem, I have been told it was causing by the low voltage of the battery. The problem has come back, the flickering was randomly (both side, not at the same time) . Anyone has the same problem before on the b6 or b7?
Also want to conform if they uses th d1s bulb and if it's easy to change th bulb?
Sam
Sam
Re: Xenon flickering
do a search, but its the bulbs that need replacing due to the cold weather
I had a similar problem on my B6 S4. Changed the bulb with little difference (after a day or so) - it turned out to be the ballasts (http://forum.rs246.com/viewtopic.php?f= ... 31#p358831) Bought a replacement, fitted, problem solved:
http://www.allpartssouthwest.com/html/find_us.html
Very helpful and cheap (from memory)
On the B6 the headlight removal is straight forward whereas I believe it's a bumper off job to do the same on the B7 (no doubt a B7 owner can confirm/deny this)
Good luck
Grahame
Good luck
Grahame
Latest weekend toy: 2011 Nissan GTR
Last weekends toy: RS5 (sepang blue) SOLD
Daily runner: S4 [B6] Avant, Ebony black/cream lthr, RNSE with TV/phone, C6 alloys, Brembo GT kit, Millteks SOLD
Found out both light bulb and control unit are faulty!
spoken to paul at all parts today, probably will get some on order very soon.
also found a slight condensation on off side head light
the first couple of weeks of ownership isn't good so far, spending wise haha.
Sam
Sam
I had/have exactly the same problem.
Its more than likely the ballasts causing this problem to start with, which after a while in turn causes the bulb..
I believe the ballast pulls a stupidly high voltage for the initial "switching on" time, maybe 3-4 mins. this is the only time my lights flicker, once they are warmed up they are fine..
i believe it is quite common and has been discussed loads on audi SRS forums..
Hope this helps a little
B7 S4 Avant; Full Miltek; RS4 Brakes;
Sam,
You say you have just picked up your S4, if you have just bought the car and from a dealer/trader then it would be covered by them as they are liable for any faults identified in the first 6 months, this is enshrined in law. If you bought privately then there is no protection or help.
Reading your initial post and the supposed 'low battery voltage' fault, if the engine is running when the lights are flickering then low battery voltage could be the alternator not regulating properly rather than the battery itself but it still sounds strange as xenon headlamps don't run at 12VDC, according to wikipedia they are either 85VAC or 42VDC so flickering is most likely to be the ballast/control circuit.
Hope this helps.
Pete
Hope this helps.
Pete
hi all
ive just bought a 2006 s4 avant and when i was out test driving it noticed one bulb was flickering so told the dealer he asured me he would fit a new bulb which he must of because there is no flicker but now i have two different colour lights one blue "original" and one white "new one" ?????
any help would be great as i need amo to go back to him with
- BlingBling
Take it back to the dealer and make them put it right. Say you got pulled by the fuzz.
That sounds painful!
That's the plan but what is the correct bulb as standard ??BlingBling wrote:Take it back to the dealer and make them put it right. Say you got pulled by the fuzz.
Hello ! Anyone know???
http://www.autobulbsdirect.co.uk/D1S-Xe ... White.html
http://www.consumabulbs.com/files/bdet. ... fAodKhkn1g
http://compare.ebay.co.uk/like/30065149 ... sbar&cbt=y
Amazing what google can do. I also have 2 old bulbs (100% working which I read the details from - so cheated a little)
Happy to help
Happy to help
Nice one cheers grum did try and google but just don't have the time with a little one taking up all my home time
Grum would you sell???
Although these are 100% working (I had 2 nights of complete nightmares with bulbs and ballasts) they are old and so wouldn't want to pass them on (will just keep in a cupboard for spares that I'll probably never use). My advice would be to buy a pair - or pass the info onto Audi and allow them to foot the bill.
Good luck
Good luck
Users browsing this forum: No registered users and 44 guests
