Xenon flickering
tak1986
Xenon flickering
Post by tak1986 » Mon Dec 12, 2011 9:07 pm
Hi all,
Just picked up my b7 s4 couple of weeks ago, the xenon headlight start flickering, went to Audi for servicing and checked the problem, I have been told it was causing by the low voltage of the battery. The problem has come back, the flickering was randomly (both side, not at the same time) . Anyone has the same problem before on the b6 or b7?
Also want to conform if they uses th d1s bulb and if it's easy to change th bulb?
Sam
Rick_RS4
Re: Xenon flickering
Post by Rick_RS4 » Mon Dec 12, 2011 10:37 pm
do a search, but its the bulbs that need replacing due to the cold weather
grum71
Post by grum71 » Mon Dec 12, 2011 10:58 pm
I had a similar problem on my B6 S4. Changed the bulb with little difference (after a day or so) - it turned out to be the ballasts (http://forum.rs246.com/viewtopic.php?f= ... 31#p358831) Bought a replacement, fitted, problem solved:
http://www.allpartssouthwest.com/html/find_us.html
Very helpful and cheap (from memory)
On the B6 the headlight removal is straight forward whereas I believe it's a bumper off job to do the same on the B7 (no doubt a B7 owner can confirm/deny this)
Good luck
Grahame
Latest weekend toy: 2011 Nissan GTR
Last weekends toy: RS5 (sepang blue) SOLD
Daily runner: S4 [B6] Avant, Ebony black/cream lthr, RNSE with TV/phone, C6 alloys, Brembo GT kit, Millteks SOLD
tak1986
Post by tak1986 » Tue Dec 13, 2011 8:50 pm
Found out both light bulb and control unit are faulty!
spoken to paul at all parts today, probably will get some on order very soon.
also found a slight condensation on off side head light :? ,
the first couple of weeks of ownership isn't good so far, spending wise haha.
Sam
S4Tom
Post by S4Tom » Sun Jan 01, 2012 5:58 pm
I had/have exactly the same problem.
Its more than likely the ballasts causing this problem to start with, which after a while in turn causes the bulb..
I believe the ballast pulls a stupidly high voltage for the initial "switching on" time, maybe 3-4 mins. this is the only time my lights flicker, once they are warmed up they are fine..
i believe it is quite common and has been discussed loads on audi SRS forums..
Hope this helps a little
B7 S4 Avant; Full Miltek; RS4 Brakes;
gottanS
Post by gottanS » Tue Jan 03, 2012 11:38 am
Sam,
You say you have just picked up your S4, if you have just bought the car and from a dealer/trader then it would be covered by them as they are liable for any faults identified in the first 6 months, this is enshrined in law. If you bought privately then there is no protection or help.
Reading your initial post and the supposed 'low battery voltage' fault, if the engine is running when the lights are flickering then low battery voltage could be the alternator not regulating properly rather than the battery itself but it still sounds strange as xenon headlamps don't run at 12VDC, according to wikipedia they are either 85VAC or 42VDC so flickering is most likely to be the ballast/control circuit.
Hope this helps.
Pete
s4Thorny
Post by s4Thorny » Mon Mar 19, 2012 9:13 pm
hi all
ive just bought a 2006 s4 avant and when i was out test driving it noticed one bulb was flickering so told the dealer he asured me he would fit a new bulb which he must of because there is no flicker but now i have two different colour lights one blue "original" and one white "new one" ?????
any help would be great as i need amo to go back to him with
BlingBling
Post by BlingBling » Tue Mar 20, 2012 9:23 am
Take it back to the dealer and make them put it right. Say you got pulled by the fuzz.
grum71
Post by grum71 » Tue Mar 20, 2012 10:38 am
That sounds painful!
s4Thorny
Post by s4Thorny » Tue Mar 20, 2012 12:17 pm
BlingBling wrote:Take it back to the dealer and make them put it right. Say you got pulled by the fuzz.
That's the plan but what is the correct bulb as standard ??
s4Thorny
Post by s4Thorny » Fri Mar 23, 2012 4:29 pm
Hello ! Anyone know???
grum71
Post by grum71 » Fri Mar 23, 2012 5:56 pm
http://www.autobulbsdirect.co.uk/D1S-Xe ... White.html
http://www.consumabulbs.com/files/bdet. ... fAodKhkn1g
http://compare.ebay.co.uk/like/30065149 ... sbar&cbt=y
Amazing what google can do. I also have 2 old bulbs (100% working which I read the details from - so cheated a little)
Happy to help
s4Thorny
Post by s4Thorny » Fri Mar 23, 2012 9:41 pm
Nice one cheers grum did try and google but just don't have the time with a little one taking up all my home time
s4Thorny
Post by s4Thorny » Fri Mar 23, 2012 9:42 pm
Grum would you sell???
grum71
Post by grum71 » Fri Mar 23, 2012 9:46 pm
Although these are 100% working (I had 2 nights of complete nightmares with bulbs and ballasts) they are old and so wouldn't want to pass them on (will just keep in a cupboard for spares that I'll probably never use). My advice would be to buy a pair - or pass the info onto Audi and allow them to foot the bill.
Good luck
Users browsing this forum: No registered users and 20 guests
