Evening all,
My rear seat (B6 avant) - the double one - does not 'click' and lock when you push it back into position after folding down.
Anyone else had this problem or know of an easy fix ?
Seat Latch ?
Seat Latch ?
NOGGY B6 S4 AVANT
VW CORRADO VR6
VW CORRADO VR6
Re: Seat Latch ?
it's not "locked" is it? if it's set so you can't open it, it may be that you can't close it either
S5 Coupe, V8 on 20's with ContiSport rubber
Re: Seat Latch ?
No its not locked.....the mechanisum wont click back and lock once pushed onto the bar like the other seat does.
Anyone know if you can change the whole mechanisum ?
NOGGY B6 S4 AVANT
VW CORRADO VR6
VW CORRADO VR6
Re: Seat Latch ?
if the b6 is like the b7.. sometimes my large rear seat does not want to stay in the upright position because the handle does not return to the fully closed position on the top of the seat-back (even when you slam it back!)
sometime i have to kneel on the back seat, and push the seat-back backwards, and close the handle to the fully locked postion by hand
i think its just the latch spring has worn, or latch is sticking..
goose
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
Re: Seat Latch ?
Yeah I have tried that but it felt like I was going to snap something so I gave up.....will give it another go then.goose wrote:.......
goose
I'm sure the latch is sticking in the opening position or the return spring has popped out somehow.
NOGGY B6 S4 AVANT
VW CORRADO VR6
VW CORRADO VR6
