Can anyone recommend a trickle charger to use when the car is kept in a garage and not used for a few weeks.
Is it possible to get one that doesn't connect via crocodile clips to the battery itself as it's all tucked under the boot floor? In an ideal world I'm thinking something through the cigarette lighter by not sure if that's even possible?
Any thoughts / tips / advice appreciated.
Trickle charger?
Trickle charger?
Re: Trickle charger?
i wouldnt leave it on charge if your away for too long just incase of a fire issue, from heat build up or charger cutoff failure, you dont want to come back to a burnt car,
when i worked away i had a solar powered trickle charger, but this would be no good as you state its garaged.
- PetrolDave
Look at the chargers intended for motorhomes (RVs), they are designed to be permanently connected to the battery long term. Won't be cheap though...RS6_Dave wrote:Can anyone recommend a trickle charger to use when the car is kept in a garage and not used for a few weeks.
Have a look at These http://www.ctekchargers.co.uk/?gclid=CO ... 4Qodx2dj_Q sold a couple of them to customers and also use one myself, they also have various method of connecting them to battery other than usual direct way. Worth a look
Jason
Jason
2007 B7 RS4
Previously
C5 RS6 Saloon Avus, Phase 2 Viper Remap, Wagners, Full Milltek, Hotchkis Arb's, 390mm C6 Brake's, H&R Coilovers
Previously
- PetrolDave
That's the sort of thing I meant - the key is this part "They are also ideal if you want to leave the charger switched on for a long period of time, for example to maintain the charge of a battery on a classic car or boat over the winter period".Heardy wrote:Have a look at These http://www.ctekchargers.co.uk/?gclid=CO ... 4Qodx2dj_Q sold a couple of them to customers and also use one myself, they also have various method of connecting them to battery other than usual direct way. Worth a look
Jason
That tells you they got a proper pulsed trickle charging system and not just a cheap voltage/current profile.
I use a Golf Buggy charger on my Scoob....as recommended by the Battery dealers. They reckoned that this was the better option even when compared to bike & car chargers???
- PetrolDave
Almost certainly true - as it's designed to be left connected to the battery for long periods.Fatneck73 wrote:They reckoned that this was the better option even when compared to bike & car chargers???
I use a halfords trickle charger. If im away long term then I will get some one to put it on a week before I return. I use the points under the plenum cover not direct to the battery. All has been fine since. Been using them for years now.
