Trickle charger?
iR8V10
Trickle charger?
Post by iR8V10 » Mon May 09, 2011 6:46 pm
Can anyone recommend a trickle charger to use when the car is kept in a garage and not used for a few weeks.
Is it possible to get one that doesn't connect via crocodile clips to the battery itself as it's all tucked under the boot floor?  In an ideal world I'm thinking something through the cigarette lighter by not sure if that's even possible?
Any thoughts / tips / advice appreciated.
Rick_RS4
Re: Trickle charger?
Post by Rick_RS4 » Mon May 09, 2011 11:06 pm
i wouldnt leave it on charge if your away for too long just incase of a fire issue, from heat build up or charger cutoff failure, you dont want to come back to a burnt car,
when i worked away i had a solar powered trickle charger, but this would be no good as you state its garaged.
PetrolDave
Post by PetrolDave » Tue May 10, 2011 6:07 pm
RS6_Dave wrote:Can anyone recommend a trickle charger to use when the car is kept in a garage and not used for a few weeks.
Look at the chargers intended for motorhomes (RVs), they are designed to be permanently connected to the battery long term. Won't be cheap though...
Heardy
Post by Heardy » Tue May 10, 2011 6:52 pm
Have a look at These http://www.ctekchargers.co.uk/?gclid=CO ... 4Qodx2dj_Q sold a couple of them to customers and also use one myself, they also have various method of connecting them to battery other than usual direct way. Worth a look
Jason
2007 B7 RS4
Previously
C5 RS6 Saloon Avus, Phase 2 Viper Remap, Wagners, Full Milltek, Hotchkis Arb's, 390mm C6 Brake's, H&R Coilovers
PetrolDave
Post by PetrolDave » Wed May 11, 2011 5:54 pm
Heardy wrote:Have a look at These http://www.ctekchargers.co.uk/?gclid=CO ... 4Qodx2dj_Q sold a couple of them to customers and also use one myself, they also have various method of connecting them to battery other than usual direct way. Worth a look
Jason
That's the sort of thing I meant - the key is this part "They are also ideal if you want to leave the charger switched on for a long period of time, for example to maintain the charge of a battery on a classic car or boat over the winter period".
That tells you they got a proper pulsed trickle charging system and not just a cheap voltage/current profile.
Fatneck73
Post by Fatneck73 » Sun May 15, 2011 9:14 pm
I use a Golf Buggy charger on my Scoob....as recommended by the Battery dealers. They reckoned that this was the better option even when compared to bike & car chargers???
PetrolDave
Post by PetrolDave » Mon May 16, 2011 5:51 pm
Fatneck73 wrote:They reckoned that this was the better option even when compared to bike & car chargers???
Almost certainly true - as it's designed to be left connected to the battery for long periods.
sonny
Post by sonny » Wed May 18, 2011 1:45 pm
I use a halfords trickle charger. If im away long term then I will get some one to put it on a week before I return. I use the points under the plenum cover not direct to the battery. All has been fine since. Been using them for years now.
Return to “Electrical”
Users browsing this forum: No registered users and 23 guests
