Radio Reception
m3vhf
Radio Reception
Post by m3vhf » Fri Feb 11, 2011 2:15 pm
Hi All,
Is there anyway i can improve the radion signal on my RNSE?
I am unable to pick up Kiss 100 in my home area around Camberley, especially parked up at home. I've set the preset a few times now, but its always greyed out once i've changed channels.
Most other stations pick up ok, quite frustrating as all my previous cars were fine in my area. Is bad reception a common problem on the RNSE?
Can i amplify the signal, or does it already have on built in?
PetrolDave
Re: Radio Reception
Post by PetrolDave » Fri Feb 11, 2011 2:30 pm
m3vhf wrote:Is bad reception a common problem on the RNSE?
Only if you have retrofitted an RNS-E to an Audi that had a Series II+ radio - as they use different diversity systems.
m3vhf wrote:Can i amplify the signal, or does it already have on built in?
All Audis have amplified diversity antenna systems.
m3vhf
RE: Re: Radio Reception
Post by m3vhf » Fri Feb 11, 2011 8:31 pm
Ok thanks. Mine isnt retrofitted. Don't supose there is anyway of increasing the gain on the antenna?
PetrolDave
Re: RE: Re: Radio Reception
Post by PetrolDave » Sat Feb 12, 2011 11:00 am
m3vhf wrote:Ok thanks. Mine isnt retrofitted. Don't supose there is anyway of increasing the gain on the antenna?
Nope, actually you've got 4 antennas and a high gain amplifier setup already.
Maybe the amplifier isn't working?
I can pick up BBC Radio Solent in Camberley in my RS4 but in my other cars it disappears around Winchester - that's why I suspect you may have an amplifier problem (there's no VAG-COM diagnostics on the amplifiers).
m3vhf
RE: Re: RE: Re: Radio Reception
Post by m3vhf » Sat Feb 12, 2011 4:07 pm
Thanks Dave, do you know where the radio amp is located (B7 RS4)? I would like to see if i can remove it and check the connections & part number before getting a new one.
PetrolDave
Post by PetrolDave » Sat Feb 12, 2011 7:02 pm
Depends on if you have a saloon, avant or cab - and whether you have the TV option.
m3vhf
Post by m3vhf » Sat Feb 12, 2011 7:05 pm
It's a Saloon without TV option.
PetrolDave
Post by PetrolDave » Sat Feb 12, 2011 7:56 pm
I'm 99% certain the amp on the saloon is above the rear window.
Return to “Electrical”
Users browsing this forum: No registered users and 115 guests
