Hi All,
Is there anyway i can improve the radion signal on my RNSE?
I am unable to pick up Kiss 100 in my home area around Camberley, especially parked up at home. I've set the preset a few times now, but its always greyed out once i've changed channels.
Most other stations pick up ok, quite frustrating as all my previous cars were fine in my area. Is bad reception a common problem on the RNSE?
Can i amplify the signal, or does it already have on built in?
Radio Reception
- PetrolDave
Re: Radio Reception
Only if you have retrofitted an RNS-E to an Audi that had a Series II+ radio - as they use different diversity systems.m3vhf wrote:Is bad reception a common problem on the RNSE?
All Audis have amplified diversity antenna systems.m3vhf wrote:Can i amplify the signal, or does it already have on built in?
RE: Re: Radio Reception
Ok thanks. Mine isnt retrofitted. Don't supose there is anyway of increasing the gain on the antenna?
- PetrolDave
Re: RE: Re: Radio Reception
Nope, actually you've got 4 antennas and a high gain amplifier setup already.m3vhf wrote:Ok thanks. Mine isnt retrofitted. Don't supose there is anyway of increasing the gain on the antenna?
Maybe the amplifier isn't working?
I can pick up BBC Radio Solent in Camberley in my RS4 but in my other cars it disappears around Winchester - that's why I suspect you may have an amplifier problem (there's no VAG-COM diagnostics on the amplifiers).
RE: Re: RE: Re: Radio Reception
Thanks Dave, do you know where the radio amp is located (B7 RS4)? I would like to see if i can remove it and check the connections & part number before getting a new one.
- PetrolDave
Depends on if you have a saloon, avant or cab - and whether you have the TV option.
It's a Saloon without TV option.
- PetrolDave
I'm 99% certain the amp on the saloon is above the rear window.
Users browsing this forum: No registered users and 159 guests
