Time to check your auxiliary radiators...
neckarsulm
..I had a quick look at mine while on a ramp and was amazed at the crud in there so very soon it's grilles off and vacuum on.
(the crud retains moisture and eventually causes corrosion of the rads)
Re: Time to check your auxiliary radiators...
Yep, mine are slowly dripping now, been quoted off Audi £610 to sort including labour. Will see if my 3rd party warranty will cover it, mmm...neckarsulm wrote:..I had a quick look at mine while on a ramp and was amazed at the crud in there so very soon it's grilles off and vacuum on.
Is that to replace the pair ? I keep mine clean but am beginning to have my suspicions about them...wrekka wrote:Yep, mine are slowly dripping now, been quoted off Audi £610 to sort including labour. Will see if my 3rd party warranty will cover it, mmm...neckarsulm wrote:..I had a quick look at mine while on a ramp and was amazed at the crud in there so very soon it's grilles off and vacuum on.
Yes to replace the pairMB2 wrote:Is that to replace the pair ? I keep mine clean but am beginning to have my suspicions about them...wrekka wrote:Yep, mine are slowly dripping now, been quoted off Audi £610 to sort including labour. Will see if my 3rd party warranty will cover it, mmm...neckarsulm wrote:..I had a quick look at mine while on a ramp and was amazed at the crud in there so very soon it's grilles off and vacuum on.
- Ice_Coffee
RE: Re: Time to check your auxiliary radiators...
Mrc will probably fit it for less, and you can probably get genuine replacement rads from gsf or similar for a lot less than audi money
Mrc go 1 better they get rid of the o/s one and that pesky airbox flap aswell lol
sorry to sound dim but where are these rads just so i can have a quick look at mine?
Chris
Chris
neckarsulm
in the bumper there are 3 grilles, behind the 2 outer ones are the aux rads. You may need a torch.
neckarsulm
can't see why notThis was a common problem with Porsches too. Are the leaves removable without putting the car up on a ramp?
Re: RE: Re: Time to check your auxiliary radiators...
Not so sure they do remove the o/s aux. rad. Do they not remove the vacuum pump and route a length of piping direct to the bottom feed of the standard air box via the removed flap opening?lengster1 wrote:Mrc go 1 better they get rid of the o/s one and that pesky airbox flap aswell lol
RS4 B7 Phantom Black
- PetrolDave
It's a common problem on the B6/B7 S4 as well. In fact it was so common on the B6 S4 that they redesigned this area on the B7, but it still seems to be a problem area (I had my OS one replaced in 2009).klauster wrote:had mine replaced under warranty, apparantly its a common problem on the RS4 so the dealer said
neckarsulm
Problem with RS4 one is that while the honeycombe prevents less debris getting down there compared to single slat of B7 S4, its much harder to see
The honeycomb grills just pull out with a good tug...very easy..clean out...then they just clip back on...simples!!
I clean mine out every month...all kinds of debris gets in there!!!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Users browsing this forum: Bing [Bot] and 112 guests
