Really want to go for the wider tyre as think it will make it look far better
275/30/19 will they rub?
Hi, I have read a few people on here are running a 275/30/19 tyre, could you tell me if there is any rub with them atall? There going on an avant and I do have it fully loaded at times. Last thing I want is it to rub when I have 4 people with luggage in.
10mm H&R hubcentrics. Coilovers may drop ride height too much to allow a heavy load and 275's but I can't really say as I don't have this set up. You'll still have a DRC warranty if less than 75k miles so go and get it fixed if you are worried or at least pressure tested. Dependent on dealer, they'll eithr do the test FOC or minimal charge. Pressure should be somewhere between 14 and 16 Bar.weenie wrote:Ooo, ok. What size spacers are you running? I was just a little worried as I parked on un-even ground today which pushed the rear wheel up into the are. I could only just fit my finger between the wheel and the inside of the arch then so thought it would make that tyre size a no go!
here's the letter
http://www.jlosee.com/images/RS4/PDF/DRC%20Letter.pdf
- PetrolDave
Users browsing this forum: Zyox and 242 guests
