Airbox flap DIY guide
neckarsulm
RE: Airbox flap DIY guide
Great write up, very helpful. I came close to purchasing one of the ITG air filters.
Top effort i appreciate your time in doing it for everyones benefit,i will take you up on your offer of supplying me a new solenoid valve please,pm me details Thanks Rich
Great write up - wish that had been around a month or so ago! I ended up paying Audi - though they did only charge me 1/2 hour labour to remove the airbox and lube up the flap mechanism. All seems to be working ok since.
2007 B7 RS4 Daytona Avant (the daily driver)
Other current toys: 210bhp Caterham 7 (track toy), 1994 380bhp Escort Cosworth Monte (awaiting engine rebuild), MX5 1.8 Sport (strictly my wife's!)
Gone: Nissan 350z roadster, 205 GTI Mi16, Classic Impreza 2000 Turbo, Nissan Sunny GTiR, Corrado G60, 205 GTI 1.9, Rover Metro Gta (don't ask!), Escort 1.6i cabbie, MG Metro (first car)
excellent thanks
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
neckarsulm
Dave, 1/2 an hour is bloody good, are you sure they removed it completely as you can lube it with just the airbox lid off or even with just the snorkel out and a bit of spraying behind the headlamp.
I'd say 1.5 to 2 hrs with diagnosis
I'm going to add part numbers and prices (after which I'll PM you Rich as don't have price here) and also a link to video of the flap working and also a defective one.
well done, this will be a excellent guide to owners in the future....
neckarsulm
Glad you like it and of course I am happy to incorporate any suggestions.
Just updated it with videos of good and bad flaps (right at end) and scrawled on some of the images to clarify things.
Price and part numbers I'll do tomorrow.
neckarsulm
I did think that, so will do!
If you can tell me which pics in particular are hard to place I will take the pics that show them in context
Prices from Audi as of 20/10/10 are as follows
Air box base (inc flap) 079129614D £56.37 + VAT = £66.24
Solenoid valve 037906283C £48.42 + VAT = £56.90
neckarsulm
Sorry I didn't reply, it wont do any harm, just might knock the timing back a bit at the top end.I refer back to a post i made a few weeks ago. My flap is sticking in the open position. How bad is this to leave it like that ?
As for it sticking, undo the vac pipe and see if it still sticks, if it does it's the flap sticking on body. It might pop itself free over time as the spring pressure is quite high hence why it's shut when you go back to it.
I doubt it'll be the valve as with the engine off this isn't energised anyway
Thanks for the replyneckarsulm wrote:Sorry I didn't reply, it wont do any harm, just might knock the timing back a bit at the top end.I refer back to a post i made a few weeks ago. My flap is sticking in the open position. How bad is this to leave it like that ?
Why would it knock back timing on top end ? Wouldnt it pull back under 5000 rpm as now its sucking in hot air. Top end it should be open afaik.
How can i lube it without taking the entire airbox out ?
neckarsulm
Not so much demand on timing at lower revs, needs to be advanced as far as it feels safe to get max efficiency at higher revs, hot air/bad fuel will peg this back and reduce power output, that's all.Why would it knock back timing on top end ? Wouldnt it pull back under 5000 rpm as now its sucking in hot air. Top end it should be open afaik.
Look at first pic, from the diaphragm to the flap is a linkage, you need to lube this while operating the flap with your hand through the snorkel inlet. The diaphragm all tucked behind and under the headlamp so use a torch to locate it and spray away using flexi nozzle
Thanks, how about i just spray the <beep> out of everythingneckarsulm wrote:Not so much demand on timing at lower revs, needs to be advanced as far as it feels safe to get max efficiency at higher revs, hot air/bad fuel will peg this back and reduce power output, that's all.Why would it knock back timing on top end ? Wouldnt it pull back under 5000 rpm as now its sucking in hot air. Top end it should be open afaik.
What spray do you recommend ? WD40 ?
Users browsing this forum: No registered users and 212 guests
