Water Leak
2.7 V6 30v biturbo - 380 bhp
beastman
Water Leak
Post by beastman » Sun Aug 22, 2010 4:12 pm
Just noticed a steady drip of coolant (thought had smelt like running hot but temp was always 90) underneath on passenger side directly under A pillar and about a foot in from tyre. Expansion tank is down to minimum so have topped up.
Any ideas what is likely to be leaking no steam rising from anywhere, yet, just the drip. Getting clutch done in fortnight but if gonna be pricey fix would delay that.
Diesel, fuel of the devil!
neckarsulm
RE: Water Leak
Post by neckarsulm » Sun Aug 22, 2010 7:21 pm
Try a new cap before you do anything else.
beastman
Re: RE: Water Leak
Post by beastman » Sun Aug 22, 2010 7:31 pm
neckarsulm wrote:Try a new cap before you do anything else.
will do the boss (wife) wud be delighted if that simple :)
jimbo1234567
RE: Re: RE: Water Leak
Post by jimbo1234567 » Wed Aug 25, 2010 10:30 pm
thats pretty much around where the expansoin tank overflow pipe comes down.
beastman
Re: RE: Re: RE: Water Leak
Post by beastman » Thu Aug 26, 2010 3:17 am
jimbo1234567 wrote:thats pretty much around where the expansoin tank overflow pipe comes down.
yeah checked it and dry, checked wi Jon @ Vagtech (who do all work on it) and thinks its the aux pump which sits between the v he had to change his recently as plastic housing had split.
will find out shortly.
beastman
Post by beastman » Sat Sep 18, 2010 11:55 pm
was as thought apparently cracks fairly easily due to heat from engine but coolant dries and seals it up, mine at 130k was well knackered!
Users browsing this forum: Majestic-12 [Bot] and 22 guests
