Just noticed a steady drip of coolant (thought had smelt like running hot but temp was always 90) underneath on passenger side directly under A pillar and about a foot in from tyre. Expansion tank is down to minimum so have topped up.
Any ideas what is likely to be leaking no steam rising from anywhere, yet, just the drip. Getting clutch done in fortnight but if gonna be pricey fix would delay that.
Water Leak
Water Leak
Diesel, fuel of the devil!
neckarsulm
RE: Water Leak
Try a new cap before you do anything else.
Re: RE: Water Leak
will do the boss (wife) wud be delighted if that simpleneckarsulm wrote:Try a new cap before you do anything else.
jimbo1234567
- 5th Gear
RE: Re: RE: Water Leak
thats pretty much around where the expansoin tank overflow pipe comes down.
665 bhp + 586 lbft...
Re: RE: Re: RE: Water Leak
yeah checked it and dry, checked wi Jon @ Vagtech (who do all work on it) and thinks its the aux pump which sits between the v he had to change his recently as plastic housing had split.jimbo1234567 wrote:thats pretty much around where the expansoin tank overflow pipe comes down.
will find out shortly.
was as thought apparently cracks fairly easily due to heat from engine but coolant dries and seals it up, mine at 130k was well knackered!beastman wrote:yeah checked it and dry, checked wi Jon @ Vagtech (who do all work on it) and thinks its the aux pump which sits between the v he had to change his recently as plastic housing had split.jimbo1234567 wrote:thats pretty much around where the expansoin tank overflow pipe comes down.
Users browsing this forum: No registered users and 137 guests
