tyre pressure warning light
Teutonic_Tamer
- 2nd Gear
Hmmmm . . . I've got an amber warning light for tyre pressures flickering away in my dash!. It is NOT the usual TMPS warning that appears in the DIS - but is actually a warning light, similar to main beam!
The owners manual makes no reference to this particular warning light (though it does detail the TPMS DIS warnings). VCDS is not throwing any relevent DTCs, and I've tried the reset procedures for both tyre pressures and wheel changes - but to no avail.
Any clues?
Any clues?
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
Angelo_Amato
- 1st Gear
- northernpar
- 2nd Gear
I had this when I had the rear tyres changed and the wheels were put back on in a different order. Wheel change reset cured it so best guess would be that at least one of the TPMS sensors can't be read. IIRC you can view the sensor readings on VCDS but I can't remember which channels. At least that would tell you if they are reading and if not which one is out.
Teutonic_Tamer
- 2nd Gear
OK, no new tyres fitted, no wheel changes or rotations, and VCDS reads all four tyre pressures OK (or it did when I first checked it).
But are you both sure you had a little warning light, rather than the big warning with a 'gong' in the larger central DIS (trip compooter/radio/navi/oil temp). Mine was not in the DIS, but was just a basic warning lamp in the top of the instrument panel (immediately above the battery warning light, and to the immediate left of the cruise control warning light). Like I said, this particular warning light which I'm getting is NOT in the owners manual or quick reference guide available here http://rs246.com/index.php?name=Downloa ... tit&lid=87.
This sounds like what I had and its to do with the senors or receiver being faulty... mine turned out to be the rear axle receiver, which was replaced under warranty
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
Teutonic_Tamer
- 2nd Gear
Angelo_Amato
- 1st Gear
- northernpar
- 2nd Gear
Users browsing this forum: No registered users and 257 guests
