SD Cards - Size is everything
I am looking to buy an SD card to put some music on via the SD slot behind the main screen on the entertainment system. Can anyone say the largest size one they have got to work with the Audi system?
Actual link to item would be appreciated.
- PetrolDave
No and in a "normal" RNS-E they never will.stenning wrote:thanks has anyone got a 8gb to work?
Why? The "normal" RNS-E only works with SD cards, and not SDHC cards - and the maximum size of an SD card is 4GB.
SD card size: <= 4GB.
SDHC card size: >= 4GB (max 32GB, above that would be an SDXC card).
So up to 2GB is an SD card, 8GB upwards is an SDHC card, 4GB can be either.
I kept saying "normal" RNS-E above because the new 2010 RNS-E does work with SDHC cards.
- PetrolDave
- PetrolDave
I recently bought Kingston & SanDisk 4GB SD cards but neither worked in the RNS-E same "reading card" & then eventually "empty". I am having some corespondence with SanDisk as to why they marked their SDHC cards up as SD but at the moment have given up on 4GB cards as I also found at 192 KBs I wasn't getting a lot more songs on the cards anyway before I hit the 512 files & folders limit & can't be bothered to re-rip at a higher Bitrate.
- PetrolDave
That's because 12GB cards are SDHC cards - and as has been posted here many times the pre-2010 RNS-E doesn't work with SDHC cards.Kal321 wrote:i've tried 12gb cards and the screen just shows reading card. it never reaches a conclusion
up to 2GB -> SD.
4GB -> SD or SDHC, but most are SDHC now.
8GB or greater -> SDHC.
Users browsing this forum: Google [Bot] and 154 guests
