SD Cards - Size is everything
stenning
Post by stenning » Wed Nov 25, 2009 12:19 pm
I am looking to buy an SD card to put some music on via the SD slot behind the main screen on the entertainment system. Can anyone say the largest size one they have got to work with the Audi system?
Actual link to item would be appreciated.
mark758
Post by mark758 » Wed Nov 25, 2009 1:08 pm
stenning
Post by stenning » Wed Nov 25, 2009 1:20 pm
thanks has anyone got a 8gb to work?
PetrolDave
Post by PetrolDave » Wed Nov 25, 2009 1:29 pm
stenning wrote:thanks has anyone got a 8gb to work?
No and in a "normal" RNS-E they never will.
Why? The "normal" RNS-E only works with SD cards, and not SDHC cards - and the maximum size of an SD card is 4GB.
SD card size: <= 4GB.
SDHC card size: >= 4GB (max 32GB, above that would be an SDXC card).
So up to 2GB is an SD card, 8GB upwards is an SDHC card, 4GB can be either.
I kept saying "normal" RNS-E above because the new 2010 RNS-E does work with SDHC cards.
stenning
Post by stenning » Wed Nov 25, 2009 1:40 pm
How can I tell what new RNS-E I have? Thanks!
PetrolDave
Post by PetrolDave » Wed Nov 25, 2009 2:47 pm
stenning wrote:How can I tell what new RNS-E I have? Thanks!
If you've got an RS4 then you haven't got a 2010 RNS-E - they're only made for the R8, TT and A3.
Sims
Post by Sims » Sun Feb 07, 2010 8:47 pm
So the best cards for an RS4 are 2gb SD cards right, or will 4GB SD also work? Thanks very much
P_G
Post by P_G » Sun Feb 07, 2010 9:42 pm
4GB will work and with that you can use a higher rip rate and get better sounds quality supposedly and still get the maximum readable 512 files on it, but I'm mutton Geoff so can't appreciate that.
Sims
Post by Sims » Sun Feb 07, 2010 9:55 pm
P_G wrote:4GB will work and with that you can use a higher rip rate and get better sounds quality supposedly and still get the maximum readable 512 files on it, but I'm mutton Geoff so can't appreciate that.
Thanks :thumbs:
PetrolDave
Post by PetrolDave » Mon Feb 08, 2010 8:29 pm
P_G wrote:4GB will work.
Provided it's an SD card and not an SDHC card - the majority of 4GB cards are now SDHC, so be VERY careful before you buy.
duud40
Post by duud40 » Mon Feb 08, 2010 9:35 pm
I almost went crazy when I saw the q5 reads sdhc cards with the basic concert stereo. :( .
Have prices on the 2010 rns-e started to drop yet?
Kal321
Post by Kal321 » Fri Feb 12, 2010 4:42 pm
i've tried 12gb cards and the screen just shows reading card. it never reaches a conclusion
MB2
Post by MB2 » Fri Feb 12, 2010 4:53 pm
I recently bought Kingston & SanDisk 4GB SD cards but neither worked in the RNS-E same "reading card" & then eventually "empty". I am having some corespondence with SanDisk as to why they marked their SDHC cards up as SD but at the moment have given up on 4GB cards as I also found at 192 KBs I wasn't getting a lot more songs on the cards anyway before I hit the 512 files & folders limit & can't be bothered to re-rip at a higher Bitrate.
PetrolDave
Post by PetrolDave » Fri Feb 12, 2010 5:33 pm
Kal321 wrote:i've tried 12gb cards and the screen just shows reading card. it never reaches a conclusion
That's because 12GB cards are SDHC cards - and as has been posted here many times the pre-2010 RNS-E doesn't work with SDHC cards.
up to 2GB -> SD.
4GB -> SD or SDHC, but most are SDHC now.
8GB or greater -> SDHC.
Sims
Post by Sims » Fri Feb 12, 2010 7:07 pm
PetrolDave wrote:
up to 2GB -> SD.
Anyone know where I can get 4GB SD cards from? Amazon had 4GB SD cards , but on further investigation, it transpired there as PetrolDave suggests SDHC!!!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 170 guests
