Creaks and rattles - dealer response
approved
Post by approved » Mon Nov 09, 2009 1:10 pm
Rang manchester audi this morning, due to an increase in the rattles that come from the centre console, in particular the arm rest and where it is attached.
apparently they only allow a couple of months under warranty for things like this to be covered, from registration date
i asked ( sternly) where this was documented and she said it wasnt.
thye are going to have a look this wednsesday...
anyone got any opinions on this before they try and pull my pants down?
Jt
Phil3103
RE: Creaks and rattles - dealer response
Post by Phil3103 » Mon Nov 09, 2009 2:22 pm
I've noticed the arm rest is quite rattley. It's a shame really because nothing else seems to (and mine's 3.5 years old now).
JT - I'd be interested in hearing about the outcome of this as I use Manchester Audi also.
Another issue - has anyone had any excessive condensation inside? I know some cars are more prone to this than others (and I've only had mine since the summer so not experienced and hot / cold weather conditions yet), but I wouldn't have expected it from an Audi!
RS6chris!
Post by RS6chris! » Mon Nov 09, 2009 6:23 pm
MMMM...I seem to be getting loads of condensation now also,What could be causing it and any one no a cure?? Recharge aircon maybe??
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
scub
Post by scub » Mon Nov 09, 2009 8:59 pm
i complained about some rattles and squeaks coming from the pillar area and dealer say it's normal on this car with stiff suspension.
when i first bought the RS it was very quiet inside the cabin.. now i hear some squeaks here and there.. it's tolerable but still, on a $70,000 car you shouldn't be hearing rattles and stuff squeaking.
they look for any reason to give an excuse.. i gave up and learned to live with it, but if it bothers you that much perhaps try calling audi headquarters... or you can try fixing some of the squeaks yourself.
i don't let the dealer touch my car anymore.. they are careless and for the most part, idiots when it comes to servicing these cars.
Baggins
Re: RE: Creaks and rattles - dealer response
Post by Baggins » Tue Nov 10, 2009 9:52 am
RS4414. wrote:MMMM...I seem to be getting loads of condensation now also,What could be causing it and any one no a cure?? Recharge aircon maybe??
I can remember a while back that owners said they were getting water trapped in their boot lids? Maybe now the weather's changed for the worse and there's been a few downpours this is happening and causing condensation within the car?
Just a thought.
MEV
Post by MEV » Tue Nov 10, 2009 12:59 pm
I took mine in for a DRC check and some other minor things and at the time asked them to look at a few creaks and groans internally. The main annoying one was the seat belt fastener was rubbing against the leather of thes seat and also a squeak around the rear headrest area. I found when I picked her up that they kindly put some felt in those said areas and cured at least the belt issue. Normally these squeeks are down to loose screws or plastic on plastic etc so with a little sweet talking to your tech they are normally fine to fix it and add some felt washers etc to tighten it all up.
I have been a big critic of Audi's service standards over here in the past so these sort of things tend to soften my attitude towards them slightly :) although they had no answer to my squeeking brakes however!! 50% left on the pads and discs in good nick..... driving me nuts... any ideas guys?? :?
B7 RS4 - 07 Phantom, Silver leather, 59k. Current
B5 RS4 - 01 Avus, B7 Brake kit, Miltek cat back, Sroof, leather, optics. 66k. Current
B8 RS4 - Sepang, BO, Roof, Sports Sold
C5 RS6 + # 296 Ebony black, full optics, titans, carbon and natural leather - sold and missed
B7 RS4 Avant Daytona Pearl, black optics, SS+, buckets, privacy. Sold
B5 RS4 - MRC 420. Gone but not forgotten.
approved
Post by approved » Tue Nov 10, 2009 1:14 pm
squeeky brakes need a good cleaning.
do 2-3 reasonably hard stops...
one after the other.
should clear any deposits on the discs if there is any.
this is what merc told me to do with my e55 and it worked a treat.
aidanjaye
Post by aidanjaye » Tue Nov 10, 2009 2:21 pm
Got my seat belt clip replaced as it was wearing on seat. Seamingly the stock was bent - done on warranty.
drcarrera
Post by drcarrera » Tue Nov 10, 2009 2:50 pm
I've had a persistent front brake squeel for several months now. The dealer checked them out and cleaned everything, but they still do it. Tends to be just as the car's coming to a halt. It's got worse recently - sounds like a London Taxi Cab sometimes!
Chris
06 Daytona RS4 Avant (B7)
MEV
Post by MEV » Tue Nov 10, 2009 4:50 pm
yep cheers, had that advice to slam the anchors on hard a couple of times and it does work for a day or two.... then its back.. christ I cant go around breaking everywhere like a blind granny at the ring but I get the idea!! Equally the stealers wanted 150 quid to clean out the calipers and drill holes in the discs! :shock: Even a lazy toe rag like me can bare that to part wit that sort of cash for a cleaning job!! So Im on my knees in the sh*te then at the weekend with a toothbrush and pipecleaner I suppose!! :( Theres got to be another way ..... :roll:
drcarrera
Post by drcarrera » Thu Nov 12, 2009 3:21 pm
MEV,
don't be too optimisitc about cleaning. After mine were cleaned it was better for a week or two, then came back again just as badly. :( I'll be interested to know if your cleaning works - if it does I may do mine again.
I'm a bit concerned as mine's got worse recently. It's also strange that this only started happening after the car was a couple of years old.
Don't know what the answer is really. I wonder whether replacing the pads may do the trick ...
Chris
Users browsing this forum: Zyox and 371 guests
