Modifying the neuspeed B7 S4 exhaust
SVSkiRenner
Post by SVSkiRenner » Tue Sep 22, 2009 11:06 pm
hi guys,
new to the forum, just a bit curious, has anyone tried to modify the neuspeed cat-back exhaust for the B7 S4 to fit the RS4? Ive heard of guys aspiring to fit it to their s5's, but would it be possible for the RS4? seems as if it would be easy, am i wrong? any input appreciated :D
P_G
Post by P_G » Wed Sep 23, 2009 10:44 am
Is it that much better than the options available for the RS4 that you would want to?
Between Milltek, Tubi, GMG and some custom fabricators there are already a lot of options that are built to fit rather then having the faff of modifying a modification?
SVSkiRenner
Post by SVSkiRenner » Fri Sep 25, 2009 7:12 am
Well personally, it's my choice of sound if I even touch the exhaust. I have even thought of just getting mufflers, but i really am having a hard time touching anything on the car, because blowing $3k on pipe isn't worth it with having my higher risk of needing standard maintenance due to my type and amount of driving
SVSkiRenner
Post by SVSkiRenner » Fri Sep 25, 2009 7:15 am
P_G
Post by P_G » Fri Sep 25, 2009 9:40 am
If you find a good exhaust fabricator they should be able to alter the exhaust note to your taste to an extent whilst developing the system for you.
I would suspect it would also be a damn sight cheaper than $3K assuming that is U.S.?
SVSkiRenner
Post by SVSkiRenner » Sun Sep 27, 2009 5:13 am
Exactly, I don't need to touch the pipe too much, can't and wouldn't do anything to the cats, so even just mufflers would satisfy me, unfortunately most options for just mufflers would delete the use of exhaust valves, but I think I can deal with that
P_G
Post by P_G » Sun Sep 27, 2009 12:22 pm
THe fabricator I use reckons he should be able to cut off the rear pipe section from the OEM back box inclusive of the actuators and tips and mate them to a new back box if I ever want tjust a cat back system. However all said the OEM back boxes are pretty resilient, to improve noise you would be better with an x-pipe and new air filter first, if that is still too quiet than madify your down pipes. Changing the cats is pretty easy and won't throw up fault codes if done properly.
SVSkiRenner
Post by SVSkiRenner » Tue Sep 29, 2009 10:23 pm
Oh I'm not worried about deleting codes or anything, I'm worried about California laws, but who's your fabricator?
P_G
Post by P_G » Tue Sep 29, 2009 11:07 pm
http://www.aas-exhausts.co.uk/
Replacing the OEM 4 cat system with 2x 200 CPSI cats wil not increase emmissions more then 10% above OEM readings if that.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 168 guests
