Hi all. I am getting a hunning sound from the front of the car which comes and goes but it only does it when the car / transmission is hot after about 1.5 hours of normal driving.
Any help whould be great.
Richard RS2
humming sound after driving for about 2 hours.
Richardrs2
RE: humming sound after driving for about 2 hours.
Brake pads failing to sit back in the caliper due to galvanisation build up between the steel backing clip & aluminium caliper body. Common issue & my educated guess. Wheel bearing usually an issue from the moment you set off.
Richardrs2
Possible, however mine gave a noise with the car stationary on throttle lift off @ 3.5k & under load with lift off throttle. You get the noise of that bearing when worn when you create load & Xs movement & then noise. It would not cause a constant noise on the run in my experience. Its the calipers
Difficult without hearing the noise but i had a simular sort of noise from the offside front which was the calipers/pads issue Alistair mentioned which is well documented and the huge amount of brake dust that had built up... mine was all sorted with new calipers and pads.
RS2 s yep ive had a few... it started with a Brilliant Black lhd then a Polar Silver and finally an RS Blau.
Users browsing this forum: No registered users and 58 guests
