humming sound after driving for about 2 hours.
2.2 I5 20v turbo - 315 bhp
Richardrs2
Post by Richardrs2 » Thu Aug 13, 2009 7:12 pm
Hi all. I am getting a hunning sound from the front of the car which comes and goes but it only does it when the car / transmission is hot after about 1.5 hours of normal driving.
Any help whould be great.
Richard RS2
alastairg
RE: humming sound after driving for about 2 hours.
Post by alastairg » Fri Aug 14, 2009 9:00 am
Brake pads failing to sit back in the caliper due to galvanisation build up between the steel backing clip & aluminium caliper body. Common issue & my educated guess. Wheel bearing usually an issue from the moment you set off.
Richardrs2
Post by Richardrs2 » Fri Aug 14, 2009 7:28 pm
Ok thanks. Would this not make the noise all of the time though not just after 1.5 hours when hot ?
Does anyone know that the situation is with diff / gearbox oil changes ? If the oil was getting hot due to a low level could it make a humming sound from the diff or gearbox ?
alastairg
Post by alastairg » Sun Aug 16, 2009 7:51 pm
Unlikely but worth changing the oil.
teknobod
Post by teknobod » Sun Aug 16, 2009 10:51 pm
Prop centre bearing?
Mine does it after 1.5-2 hours.
Andy
alastairg
Post by alastairg » Mon Aug 17, 2009 9:40 am
Possible, however mine gave a noise with the car stationary on throttle lift off @ 3.5k & under load with lift off throttle. You get the noise of that bearing when worn when you create load & Xs movement & then noise. It would not cause a constant noise on the run in my experience. Its the calipers
AlWyn
Post by AlWyn » Mon Aug 17, 2009 12:44 pm
Difficult without hearing the noise but i had a simular sort of noise from the offside front which was the calipers/pads issue Alistair mentioned which is well documented and the huge amount of brake dust that had built up... mine was all sorted with new calipers and pads.
RS2 s yep ive had a few... it started with a Brilliant Black lhd then a Polar Silver and finally an RS Blau.
