Losing Oil
wolf02
Losing Oil
Post by wolf02 » Mon Apr 20, 2009 10:58 am
Hi,
I understand that the V8 does use some oil during general driving.
But im concerned how much im having to top up.
Im having to put around 1ltr in every few months.
I dont drive the car that much, in fact very little as I work from home most of the time.
I keep experiencing the oil top up light coming on, mostly its when i drive on the motorway. The exhausts are also BLACK from the oil coming out the back.
I do drive the car fairly hard when i do take it out.
Is this normal usage ?? if not what should i look for causing the problem ?
Also, there doesnt appear to be any leaks as there is no spots on the driveway etc. So unless its leaking only when under driving conditions I dont think thats the problem.
Thanks!!
ShaneyB
RE: Losing Oil
Post by ShaneyB » Mon Apr 20, 2009 11:01 am
Ditto??
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Pete.S
Post by Pete.S » Mon Apr 20, 2009 7:26 pm
When you say 1 litre every few months, how many miles does that equate to between top ups?
Mine drinks about 2 or 3 litres in between (AVS) services (~17k miles) which is quite normal
wolf02
Post by wolf02 » Wed May 06, 2009 11:50 am
I do very few miles in my car, mostly short trips.
Its probably going through around 1 litre every 1000 miles.
Greengoblin
Post by Greengoblin » Wed May 06, 2009 12:39 pm
Sounds like you have a problem , my one uses approx 1 litre / 5000 miles
2004 S4 Avant
BlingBling
Post by BlingBling » Wed May 06, 2009 1:06 pm
What service plan are you on? You maybe using the wrong oil spec if your mileage is low. For low mileage you should be on a fixed service schedule, approx. yearly. I was suffering similar problems but switching to fixed service intervals, different oil spec, sorted it out. I do approx. 8k miles a year
wolf02
Post by wolf02 » Wed May 06, 2009 1:22 pm
Im on the yearly Audi longlife service plan, done by my local audi dealer.
Should I switch it to regular service plan ie non longlife ?
Would this help ?
BlingBling
Post by BlingBling » Wed May 06, 2009 7:51 pm
Your on the right service plan for your mileage. Do they use the correct spec? Fixed service plans should use 5W-40 fully synthetic oil.
xyber
Post by xyber » Wed May 06, 2009 9:20 pm
BlingBling wrote:What service plan are you on? You maybe using the wrong oil spec if your mileage is low. For low mileage you should be on a fixed service schedule, approx. yearly. I was suffering similar problems but switching to fixed service intervals, different oil spec, sorted it out. I do approx. 8k miles a year
Ive had this before, one brand and spec oil was fine, which was actually the manufacturers recommended oil, others just went straight through it
Thats on a low annual mileage engine, I only do about 3-4k a year and change oil and filter every April
wolf02
Post by wolf02 » Thu May 07, 2009 9:14 am
Cant be 100% sure that its the correct oil, on the receipt it says they used "SLX3 Castrol longlife oil".
Any ideas ? Plus if audi cant get it right who can you trust ?!
BlingBling
Post by BlingBling » Thu May 07, 2009 11:43 am
Check your handbook it will say what the oil spec is for fixed service intervals. AFAIK SLX3 or long life oils should not be used for fixed service intervals.
Pete.S
Post by Pete.S » Thu May 07, 2009 6:14 pm
wolf02 wrote:Cant be 100% sure that its the correct oil, on the receipt it says they used "SLX3 Castrol longlife oil".
Yep if you're on variable service that's (or that was) the right oil, now superseded by Castrol Edge
Ridgeway
Post by Ridgeway » Sun May 10, 2009 5:50 pm
I will be in a similar position, plan to run for about 5-6k p/a and so the S4 will be serviced annually.
But still not sure what oil to use ?
It is required to change the oil mid interval ie every 6 months in my case ? That's what the previous owner was doing ie Audi made the annual service and in between he changed oil and filters himself, was going to follow this but not sure after reading this :?
BlingBling
Post by BlingBling » Mon May 11, 2009 8:58 am
The fixed internal oil sped is 502, 5W-40.
@wolf02. They used the wrong oil spec during your sevice. slx3 is VW504/507. I.e. Long life
wolf02
Post by wolf02 » Mon May 11, 2009 10:24 am
Thanks, I'll have a word with them, in the short term whats my best plan?
My service is not for another 6 months, should I do a full oil change or just keep topping up.
Will it do any harm just topping up ?
Users browsing this forum: No registered users and 23 guests
