Losing Oil
Losing Oil
Hi,
I understand that the V8 does use some oil during general driving.
But im concerned how much im having to top up.
Im having to put around 1ltr in every few months.
I dont drive the car that much, in fact very little as I work from home most of the time.
I keep experiencing the oil top up light coming on, mostly its when i drive on the motorway. The exhausts are also BLACK from the oil coming out the back.
I do drive the car fairly hard when i do take it out.
Is this normal usage ?? if not what should i look for causing the problem ?
Also, there doesnt appear to be any leaks as there is no spots on the driveway etc. So unless its leaking only when under driving conditions I dont think thats the problem.
Thanks!!
Thanks!!
RE: Losing Oil
Ditto??
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
- Greengoblin
- BlingBling
What service plan are you on? You maybe using the wrong oil spec if your mileage is low. For low mileage you should be on a fixed service schedule, approx. yearly. I was suffering similar problems but switching to fixed service intervals, different oil spec, sorted it out. I do approx. 8k miles a year
- BlingBling
Ive had this before, one brand and spec oil was fine, which was actually the manufacturers recommended oil, others just went straight through itBlingBling wrote:What service plan are you on? You maybe using the wrong oil spec if your mileage is low. For low mileage you should be on a fixed service schedule, approx. yearly. I was suffering similar problems but switching to fixed service intervals, different oil spec, sorted it out. I do approx. 8k miles a year
Thats on a low annual mileage engine, I only do about 3-4k a year and change oil and filter every April
- BlingBling
I will be in a similar position, plan to run for about 5-6k p/a and so the S4 will be serviced annually.
But still not sure what oil to use ?
It is required to change the oil mid interval ie every 6 months in my case ? That's what the previous owner was doing ie Audi made the annual service and in between he changed oil and filters himself, was going to follow this but not sure after reading this
- BlingBling
