warning light... not in my manual :(
klauster
Post by klauster » Tue Mar 24, 2009 10:19 am
I had a warning light flash on yesterday, its not in the manual, well not an exact like for like. It was amber and looked something like this (don't laugh) I haven't got time to draw it exactly
Light has now gone off, but just wondered what it might be, if it comes back...
crispy
Post by crispy » Tue Mar 24, 2009 10:20 am
Susct it is something to do with the active (adaptive) xenons
gmk666
Post by gmk666 » Tue Mar 24, 2009 10:47 am
Either that or you need to turn your jellyfish 90 degrees to the left.
klauster
Post by klauster » Tue Mar 24, 2009 11:01 am
hehe :D
P_G
Post by P_G » Tue Mar 24, 2009 11:06 am
An uneducated guess would be that it is highlighting an issue with your adaptive Xenon self levelling system.
sonny
Post by sonny » Tue Mar 24, 2009 12:35 pm
I know what you mean, I have this too, a Yellow symbol (but showing a bulb) and this icon is not in the manual and I cant see any thing wrong with the car!
klauster
Post by klauster » Tue Mar 24, 2009 1:00 pm
SJ-RS4 wrote:I know what you mean, I have this too, a Yellow symbol (but showing a bulb) and this icon is not in the manual and I cant see any thing wrong with the car!
its similar to other symbols in the manual but not an exact match... I will VAG.COM it and see what i find
PetrolDave
Post by PetrolDave » Tue Mar 24, 2009 1:18 pm
It's the warning light for a fault in the headlight levelling system.
Probably needs resetting - if the prompts on VCDS (VAG-COM) don't give the instructions then try either the Ross Tech wiki http://wiki.ross-tech.com or the car procedures page on the Ross Tech website http://www.ross-tech.com/vag-com/cars/x ... nment.html
klauster
Post by klauster » Tue Mar 24, 2009 2:07 pm
PetrolDave wrote:It's the warning light for a fault in the headlight levelling system.
cheers for that
Gazzer68
Post by Gazzer68 » Tue Mar 24, 2009 10:26 pm
I had this, turned out audi hadn't connected the connecting rod properly on the suspension when changing the front drc.
It's comes up intermittently and the lights behave very erractic !
The connecting rod is attached to the front nearside suspension.
07/07 RS4 Avant Mugello Blue
RR55FOR
Post by RR55FOR » Tue Nov 17, 2009 1:23 am
This same symbol is now coming up on mine along with the EPC light. Do we have a solution or know what the problem is?
Angelo_Amato
EPC light..
Post by Angelo_Amato » Tue Nov 17, 2009 1:48 pm
can't help you with the Xenons but i know from experince with my wife's A2 a bit about the EPC light - i think it stands for engine power control and on our A2 basically comes on when the throttle body gets clogged up from the crankcase oil breather (discovered this after a long while :roll: ) this was cured by using throttle body cleaner, and this i have to do around twice a year.
May not be the same of the RS but may be of similar sorts.
i also think EPC is a catchall for a number of possible faults.
I do also remember on a Mk4 golf that i worked on had an EPC light on, turned out it was a brake light bulb gone !! it came on again a while later and was the brake light switch that had failed (common problem) ! :?
Angelo
RR55FOR wrote:This same symbol is now coming up on mine along with the EPC light. Do we have a solution or know what the problem is?
PetrolDave
Post by PetrolDave » Tue Nov 17, 2009 2:37 pm
The EPC light comes on when one or both of the engine ECUs detects a "fault" - which could be for one of many (tens) of reasons. So the only way to know what's causing the EPC light to come on is to get a VAG-COM scan done.
Users browsing this forum: No registered users and 217 guests
