275 35's could be putting things out by more than I thought!
Marcus-RS4
Post by Marcus-RS4 » Tue Feb 17, 2009 10:58 am
http://www.carbibles.com/tyre_bible_pg2.html
But its the right way ;)
Check it out!
Quite an interesting site too !
P_G
Post by P_G » Tue Feb 17, 2009 11:11 am
Very good that. I know my Speedo is over calibrated as when you go through the speed traps in urban zones the speedo can read 33-35 mph by ony read 29 on the roadside camera sign.
Ozrs4
Post by Ozrs4 » Tue Feb 17, 2009 1:07 pm
The downside with 275/30/19 is: the odometer will show more mileage than what the car actually traveled, not so good for depreciation! just a thought.
2007 RS4 B7 - Phantom black saloon
booski
Post by booski » Tue Feb 17, 2009 1:16 pm
Ozrs4 wrote:The downside with 275/30/19 is: the odometer will show more mileage than what the car actually traveled, not so good for depreciation! just a thought.
so if we put smaller tyres on will the odometer show less milesthan we actually travel??
not that i'm gonna change from the 255's- just curious :wink:
2007 RS4 (B7) Avant, Daytona grey
NonRes Milltek- SOLD......(missing her already)
Ozrs4
Post by Ozrs4 » Tue Feb 17, 2009 1:20 pm
Yes, it would but then getting a few speeding tickets coz you thought your speedo said you were only traveling at 60mph when you're actually doing 65mph is not fun either for the hip-piocket!!! haaha, can't have it both ways my friend.
PetrolDave
Post by PetrolDave » Tue Feb 17, 2009 1:30 pm
What matters is the rolling circumference - 275/30's have a smaller rolling circumference than 255/35s so the wheels turn more times per mile, which means it appears you're going further and faster than you really are.
booski
Post by booski » Tue Feb 17, 2009 1:32 pm
Ozrs4 you're a dentist like me aren't you - get working !! lol
pippyrips
Post by pippyrips » Tue Feb 17, 2009 1:42 pm
PetrolDave wrote:What matters is the rolling circumference - 275/30's have a smaller rolling circumference than 255/35s so the wheels turn more times per mile, which means it appears you're going further and faster than you really are.
Ok - so who is going to build a converter to work out true mileage?!
P_G
Post by P_G » Tue Feb 17, 2009 1:55 pm
True and I may have asked this before, is there not a way through VAG-COM to prgram in what tyres you are running or is that just RNS-E specific for it to calculate on the Sat Nav? I remember when retro fitting an RNS-E on my B6 S4 it asked for wheel size and tyre size?
There must be becasue surely thos who were running 18" wheels on the RS4, their rolling radius is never going to be the same as that on the 19's?
PetrolDave
Post by PetrolDave » Tue Feb 17, 2009 2:10 pm
P_G wrote:True and I may have asked this before, is there not a way through VAG-COM to prgram in what tyres you are running or is that just RNS-E specific for it to calculate on the Sat Nav? I remember when retro fitting an RNS-E on my B6 S4 it asked for wheel size and tyre size??
That's just to calibrate the RNS-E - it has no effect on the speedo or the odometer.
P_G
Post by P_G » Tue Feb 17, 2009 4:40 pm
I suspected that part Dave, I was more curious for those handy on VAG-COM whether something similar existed for to odometer otherwise how does it know what size wheels and tyres are on the car because they would be standard factory odometers for the entire Audi / range surely?
pippyrips
Post by pippyrips » Tue Feb 17, 2009 5:10 pm
P_G wrote:I suspected that part Dave, I was more curious for those handy on VAG-COM whether something similar existed for to odometer otherwise how does it know what size wheels and tyres are on the car because they would be standard factory odometers for the entire Audi / range surely?
Aren't they calibrated for each car/tyre etc. That plus the +/- 10% rule would cover it.
rjkflyer
Tyre calculator
Post by rjkflyer » Tue Feb 17, 2009 5:21 pm
Did this back in 1997 when a mate of mine was looking to change the tyres on his Jensen Interceptor III...
Have put starting dimensions in for RS4. Play away...
(Have to unzip it - as forum won't allow an Excel att.)
Tyre calculator.zip
(3.51 KiB) Downloaded 76 times
PetrolDave
Post by PetrolDave » Tue Feb 17, 2009 6:22 pm
P_G wrote:I was more curious for those handy on VAG-COM whether something similar existed for to odometer otherwise how does it know what size wheels and tyres are on the car because they would be standard factory odometers for the entire Audi / range surely?
They're not standard speedos/odometers across the entire range - they're specific to type, e.g. the RS4 speedo/odo is only used on the RS4, and that applies across all models/variants (look on ETKA, there is a different speedo/odo combination for each model/engine combination). Not only is the calibration different but the tacho has different redlines and the speedo has different maximums...
With VAG-COM you can calibrate the mpg reading on the trip computer by +/- 20% but there's no known calibration adjustment for the speedo/odo. I guess that's hard-coded in the firmware?
hussains
Post by hussains » Wed Feb 18, 2009 8:04 pm
Are you supposed to get the wheel alignment done when you change from 255 to 275 tyres? As I am still experiencing judders!
Users browsing this forum: No registered users and 186 guests
