But its the right way
Check it out!
Quite an interesting site too !
so if we put smaller tyres on will the odometer show less milesthan we actually travel??Ozrs4 wrote:The downside with 275/30/19 is: the odometer will show more mileage than what the car actually traveled, not so good for depreciation! just a thought.
Yes, it would but then getting a few speeding tickets coz you thought your speedo said you were only traveling at 60mph when you're actually doing 65mph is not fun either for the hip-piocket!!! haaha, can't have it both ways my friend.booski wrote:so if we put smaller tyres on will the odometer show less milesthan we actually travel??Ozrs4 wrote:The downside with 275/30/19 is: the odometer will show more mileage than what the car actually traveled, not so good for depreciation! just a thought.
not that i'm gonna change from the 255's- just curious
Ok - so who is going to build a converter to work out true mileage?!PetrolDave wrote:What matters is the rolling circumference - 275/30's have a smaller rolling circumference than 255/35s so the wheels turn more times per mile, which means it appears you're going further and faster than you really are.
True and I may have asked this before, is there not a way through VAG-COM to prgram in what tyres you are running or is that just RNS-E specific for it to calculate on the Sat Nav? I remember when retro fitting an RNS-E on my B6 S4 it asked for wheel size and tyre size?Ozrs4 wrote:The downside with 275/30/19 is: the odometer will show more mileage than what the car actually traveled, not so good for depreciation! just a thought.
That's just to calibrate the RNS-E - it has no effect on the speedo or the odometer.P_G wrote:True and I may have asked this before, is there not a way through VAG-COM to prgram in what tyres you are running or is that just RNS-E specific for it to calculate on the Sat Nav? I remember when retro fitting an RNS-E on my B6 S4 it asked for wheel size and tyre size??
Aren't they calibrated for each car/tyre etc. That plus the +/- 10% rule would cover it.P_G wrote:I suspected that part Dave, I was more curious for those handy on VAG-COM whether something similar existed for to odometer otherwise how does it know what size wheels and tyres are on the car because they would be standard factory odometers for the entire Audi / range surely?
They're not standard speedos/odometers across the entire range - they're specific to type, e.g. the RS4 speedo/odo is only used on the RS4, and that applies across all models/variants (look on ETKA, there is a different speedo/odo combination for each model/engine combination). Not only is the calibration different but the tacho has different redlines and the speedo has different maximums...P_G wrote:I was more curious for those handy on VAG-COM whether something similar existed for to odometer otherwise how does it know what size wheels and tyres are on the car because they would be standard factory odometers for the entire Audi / range surely?
Users browsing this forum: Bing [Bot] and 468 guests
