Headlight Knocked out of Place
moog
Post by moog » Mon Dec 29, 2008 9:37 am
Hello all,
Looks as though someone has knocked into the front of my RS4, albeit fairly gently, and whilst there is no obvious damage to the body work (barring a v minor little scrape) it seems that the contact has popped the head light slightly out of its housing - the front drivers side headlight now sticks slightly out at the side rather than being flush against the wing.
Does anyone know if this might be easy to sort out myself, bearing in mind I have no practical skills at all, or should I leave it to the professionals.
Tks.
PetrolDave
RE: Headlight Knocked out of Place
Post by PetrolDave » Mon Dec 29, 2008 10:08 am
I thought the same after a minor bump last year, but it turned out that the beam behind the bumper was bent which was making the headlight stick out.
Get a decent bodyshop to look at it.
rs4v8
Post by rs4v8 » Mon Dec 29, 2008 2:35 pm
I managed to drop a bulb inside the headlamp itself and tried to take the whole headlamp off to remove it. Gave up in the end as it appeared to be a bumper off job.
I'm with PetrolDave, get someone to do it for you.
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
Jezzer
Re: RE: Headlight Knocked out of Place
Post by Jezzer » Mon Dec 29, 2008 4:29 pm
rs4v8 wrote:I managed to drop a bulb inside the headlamp itself and tried to take the whole headlamp off to remove it. Gave up in the end as it appeared to be a bumper off job.
You wouldn't need to take the bumper off completely just lower it down slightly off its mounts. You may find it clicks back in to place just by pulling it back with your hand.
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
Users browsing this forum: Google Adsense [Bot] and 144 guests
