Rubbish AM Reception
Hi, I have terrible AM reception on my RNS D sat nav unit. I listen to Absolute radio (Virgin Radio) daily but recently I have found the reception to be very poor. This has never happend before in any radio that I have had in my car only this one.
Can anyone suggest an idea to cure this? Is it a case of fitting a new ariel that will increase signal strength or am I barking up the wrong tree!
Thanks Paul
Thanks Paul
- PetrolDave
RE: Rubbish AM Reception
The RNS-D connects to a diversity antenna system in the car that already has built-in amplifiers. Sounds like maybe one of them has gone faulty.
What's FM reception like?
Is reception any better or worse when you turn the heated rear window on?
- PetrolDave
Hi everyone - I noticed this the other day - rear heater switched on badly affected my FM reception. Is this a common fault? what's the fix?lushman wrote:Hi, FM is great. There is no obvious change when the rear heater is switched on,
Paul
I also too had non existent AM reception but Audi fixed it for a while with a new Antenna base (f@cking expensive, but under warranty). Now I have another source of interference being a consistent but intermittent whine on AM, which seems to disappear when engine is switched off. Any ideas anyone?
Olly
Hi Folks, I have finally discovered my poor AM reception. Diversity switch as petrol dave diognosed for me.
With the woes I have been having in getting the right cable for the Phatbox to connect to the cd changer cable I had to remove the cables from the diversity switch and discovered one of the pins on the radio cable to be corroded. I tried cleaning it, however the corrosion has obviously spread onto the circuit board.
I unfortunately took the decision to order from the stealers for £111, but if I can listen to my AM without all the interference I will be a happy man!
Paul
Paul
C7 RS6 coming soon
2006 B7 RS4 Avant Sprint Blue & Black Optics - Gone
2000 Avus Silver B5 RS4 - Gone
- PetrolDave
Yes that's a very common fault. The rear window heater is also used as an aerial so there is a filter unit that blocks the DC from the aerial input of the radio, when that filter fails you get poor FM reception. The cure is to replace it.ollys wrote:Hi everyone - I noticed this the other day - rear heater switched on badly affected my FM reception. Is this a common fault? what's the fix?
