Non-Starter...
2.7 V6 30v biturbo - 380 bhp
cossymad
Non-Starter...
Post by cossymad » Tue Oct 28, 2008 4:13 pm
Car has been problem free for over a year then it won't start.
It fires up for like 2 seconds, then dies.
I tried it loads of time, all the same.
Fuel pump buzzes away, all lights go out.
I left it over night, tried it in the moring. It fired up and idled (albeit low) for 10 seconds, then when I went to press accelerator, it died and wouldn't start.
Idea's?
I thought MAF. Is this a symptom?
:greyrs4: :FIREdevil:
MTM air freshner,
98ron V Power,
Child seat
509 bhp
philipwalker
RE: Non-Starter...
Post by philipwalker » Tue Oct 28, 2008 4:26 pm
Key coding, problem with the reader coil on the lock not picking up the key?
The stored fault codes should send you in the right direction.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
cossymad
Re: RE: Non-Starter...
Post by cossymad » Tue Oct 28, 2008 4:40 pm
philipwalker wrote:Key coding, problem with the reader coil on the lock not picking up the key?
Hmm I could try the spare key too. Could this also be at fault?
MTM air freshner,
98ron V Power,
Child seat
509 bhp
rsmonkey918
RE: Re: RE: Non-Starter...
Post by rsmonkey918 » Tue Oct 28, 2008 5:09 pm
Had an intermittent problem on the gf's TT- sometimes first time, sometimes have to wait for the immobiliser light to go out, sometimes have to try a couple more times. Advised by Audi (!) that it could be either the reader coil or the key but the random nature means if we tried the other key it maybe coincidental that it fires up- advised to wait until it becomes permanent....... cheers Audi....... :beerchug:
Regards
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
frazered
Post by frazered » Tue Oct 28, 2008 6:12 pm
sounds just like keys coding - had the same a few months back as I had bought another key but the dealers had not coded it properly
dace
Post by dace » Tue Oct 28, 2008 7:18 pm
Also had the same issues with my daughters Polo. Very intermittent and ended up being a faulty reader coil
sonny
Post by sonny » Wed Oct 29, 2008 6:55 am
I had a non starter issue with my B7 RS4, when pushing the start button nothing happened, it later turned out to be the starter motor, in it went to Audi, and 3 days later came out with a new radiator, starter motor and alternator..would you believe it,i was caused by corrosion!
hopefully your wont be a severe as that...hmmm TBH I never though about trying the second key!
cossymad
Post by cossymad » Wed Oct 29, 2008 9:40 am
I think it is the water temp sensor.
On diagnostic it was reading water temp as 102c. Car had not been started for days, and air temp was 7c!!
MTM air freshner,
98ron V Power,
Child seat
509 bhp
rtd
Post by rtd » Wed Oct 29, 2008 9:53 am
cossy mad i think you might be right as mine has been diagnosed with this fault as well with same sort of symptoms.......
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
cossymad
Post by cossymad » Wed Oct 29, 2008 10:37 am
Well in theory if the sensor is telling the ecu it is 102c then the ecu will not bother with coldstart, and secondly to compensate for the heat, the fuel will be pouring in, running so rich it will...well not run!!
MTM air freshner,
98ron V Power,
Child seat
509 bhp
Blue_Thunder
Post by Blue_Thunder » Wed Oct 29, 2008 10:44 am
At least it's an easy fix. Winner!
cossymad
Post by cossymad » Wed Oct 29, 2008 4:11 pm
Hopefully!!
MTM air freshner,
98ron V Power,
Child seat
509 bhp
