Very Hard Brake Pedal
2.7 V6 30v biturbo - 380 bhp
simoncotton
Post by simoncotton » Fri Sep 05, 2008 5:58 pm
I have been out today in the pouring rain, loads of standing water / floods.
I noticed that the brake pedal went really hard, very little travel whatsoever, almost as if the pedal hard been pumped really hard.
Has anyone else experienced this? Made me very nervous.
Running Movit Brakes and discs all round.
quattronutter
RE: Very Hard Brake Pedal
Post by quattronutter » Sat Sep 06, 2008 12:16 am
check the vac line to brake servo,bulkhead joint is the weak link
imolas4uk
Post by imolas4uk » Sat Sep 06, 2008 11:37 pm
i have seen a few brake servos full of water due to blocked phelnum chamber drains (where the battery is fitted) if its full of water clear the drains then pull off the servo vac hose and syphon the water from the servo :audibash:
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
tdiquattro
Post by tdiquattro » Sun Sep 07, 2008 9:13 am
It's just the ESP, the car applies the brakes when needed, especially in the wet, and if you happen to hit the pedal whilst it is doing that you will feel it is rock hard, - a bit off putting at times!
Nothing to worry about this is completely normal :-)
Nige'
2000 silver S4 Saloon
