I have been out today in the pouring rain, loads of standing water / floods.
I noticed that the brake pedal went really hard, very little travel whatsoever, almost as if the pedal hard been pumped really hard.
Has anyone else experienced this? Made me very nervous.
Running Movit Brakes and discs all round.
Very Hard Brake Pedal
simoncotton
- 1st Gear
quattronutter
RE: Very Hard Brake Pedal
check the vac line to brake servo,bulkhead joint is the weak link
i have seen a few brake servos full of water due to blocked phelnum chamber drains (where the battery is fitted) if its full of water clear the drains then pull off the servo vac hose and syphon the water from the servo
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
- tdiquattro
It's just the ESP, the car applies the brakes when needed, especially in the wet, and if you happen to hit the pedal whilst it is doing that you will feel it is rock hard, - a bit off putting at times!
Nothing to worry about this is completely normal
Nige'
2000 silver S4 Saloon
