Anyone seen this before?
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 02325
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
ABS error code
ABS error code
- 2nd Gear
RE: ABS error code
Sure...
http://wiki.ross-tech.com/index.php/18265/P1857/006231
...any codes stored in your ECU? Might be MAF related...
Sebastian @ Ross-Tech.com
Re: RE: ABS error code
How do I access codes stored in the ECU? I thought that exactly what these DTC codes that VAG-COM get for youSebastian wrote:Sure...
Just fitted a new MAF a couple of weeks ago.
- Virdee Autos
- Trader (Expired)
RE: Re: RE: ABS error code
Just go into Engine (01) and just check for any fault codes. Present and stored will both be shown
Virdee Autos ~ 07950-526592
- 2nd Gear
Hmm... did you clear codes after you fitted the new MAF? You may wanna try that and see if the code comes back.
Had this on mine
Controller: 8D0 907 389 E
Coding: 04395
Shop #: WSC 02325
No fault code found.
But then it said no fault found.
Coding: 04395
Shop #: WSC 02325
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
2006 BMW M6 - GONE
Re: RE: Re: RE: ABS error code
Yep, cleared all codes from the Engine controller post MAF fitment.Sebastian wrote:Hmm... did you clear codes after you fitted the new MAF? You may wanna try that and see if the code comes back.
Done another full scan tonight after running it for a few hundred miles, and its not re-occured.
