ABS error code
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
TopBear
ABS error code
Post by TopBear » Thu May 29, 2008 11:32 pm
Anyone seen this before?
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 02325
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
Sebastian
RE: ABS error code
Post by Sebastian » Fri May 30, 2008 2:40 pm
Sure...
http://wiki.ross-tech.com/index.php/18265/P1857/006231
...any codes stored in your ECU? Might be MAF related...
Sebastian @ Ross-Tech.com
TopBear
Re: RE: ABS error code
Post by TopBear » Fri May 30, 2008 2:55 pm
Sebastian wrote:Sure...
How do I access codes stored in the ECU? I thought that exactly what these DTC codes that VAG-COM get for you :?
Just fitted a new MAF a couple of weeks ago.
Virdee Autos
Trader (Expired)
RE: Re: RE: ABS error code
Post by Virdee Autos » Fri May 30, 2008 8:58 pm
Just go into Engine (01) and just check for any fault codes. Present and stored will both be shown
Virdee Autos ~ 07950-526592
Sebastian
Post by Sebastian » Sun Jun 01, 2008 9:36 pm
Hmm... did you clear codes after you fitted the new MAF? You may wanna try that and see if the code comes back.
Contigo
Post by Contigo » Mon Jun 02, 2008 10:04 pm
Had this on mine
Controller: 8D0 907 389 E
Coding: 04395
Shop #: WSC 02325
No fault code found.
But then it said no fault found.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
TopBear
Re: RE: Re: RE: ABS error code
Post by TopBear » Mon Jun 02, 2008 10:17 pm
Sebastian wrote:Hmm... did you clear codes after you fitted the new MAF? You may wanna try that and see if the code comes back.
Yep, cleared all codes from the Engine controller post MAF fitment.
Done another full scan tonight after running it for a few hundred miles, and its not re-occured.
Return to “DTC / VCDS”
