Help! Big vibration from rear diff!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
rosshyslop
Post by rosshyslop » Wed May 21, 2008 2:22 pm
Usually a bit of vibration goes hand in hand with some of those top shelf DVD's you can buy down seedy back streets.....unfortunately this time its coming from the back of my car. It happens on tight turns (coming out of junctions etc) when i accelerate gently. Its a kind of hard vibration which sounds like its coming from the rear diff. Can anyone help as this seems like its going to be expensive?!
Cheers, ross.
mikeyquattro
RE: Help! Big vibration from rear diff!
Post by mikeyquattro » Wed May 21, 2008 3:09 pm
have you checked the prop shaft bearing?
Tomorrow is another day
tdiquattro
Post by tdiquattro » Wed May 21, 2008 3:43 pm
This is normal, it is the centre diff, all mechanical quattros make that noise when turning sharply at very slow speed. Don't worry !
Nige'
2000 silver S4 Saloon
rosshyslop
Post by rosshyslop » Wed May 21, 2008 3:48 pm
Not noticed it being this bad though thats all. Can't believe how paranoid i get with this car!
am8631
Post by am8631 » Wed May 21, 2008 5:27 pm
I did the same when i first got mine!!! Especially on full lock at slow speeds - luckily the forum put my mind at ease.
h8cak
Post by h8cak » Wed May 21, 2008 5:43 pm
Same here. I thought i had probs too but its how it is :)
Wide Body S4
rosshyslop
Post by rosshyslop » Wed May 21, 2008 6:44 pm
Just remembered that i had an 034 rear diff mount fitted a week and a bit ago (along with gearbox and engine mounts), so the vibrations are probably stronger coming through the chassis now. Cheers for all the replies guys!
Ross
VillageIdiot
Post by VillageIdiot » Thu May 22, 2008 12:14 pm
HAH!
I should have asked... I just bought a 2nd hand rear diff for mine as I thought it was knackered.
It is leaking oil from the driveshaft oil seals tho... and the filler plug is welded in and stripped out so I needed a new one anyhoo.
Good to know its a normal noise tho!
Mike
Users browsing this forum: No registered users and 171 guests
