Help! Big vibration from rear diff!
rosshyslop
- 1st Gear
Usually a bit of vibration goes hand in hand with some of those top shelf DVD's you can buy down seedy back streets.....unfortunately this time its coming from the back of my car. It happens on tight turns (coming out of junctions etc) when i accelerate gently. Its a kind of hard vibration which sounds like its coming from the rear diff. Can anyone help as this seems like its going to be expensive?!
Cheers, ross.
Cheers, ross.
- mikeyquattro
- Top Gear
RE: Help! Big vibration from rear diff!
have you checked the prop shaft bearing?
Tomorrow is another day
- tdiquattro
This is normal, it is the centre diff, all mechanical quattros make that noise when turning sharply at very slow speed. Don't worry !
Nige'
2000 silver S4 Saloon
rosshyslop
- 1st Gear
Not noticed it being this bad though thats all. Can't believe how paranoid i get with this car!
I did the same when i first got mine!!! Especially on full lock at slow speeds - luckily the forum put my mind at ease.
Same here. I thought i had probs too but its how it is
Wide Body S4
rosshyslop
- 1st Gear
Just remembered that i had an 034 rear diff mount fitted a week and a bit ago (along with gearbox and engine mounts), so the vibrations are probably stronger coming through the chassis now. Cheers for all the replies guys!
Ross
Ross
VillageIdiot
Users browsing this forum: Google [Bot] and 82 guests
