New posts problems
New posts problems
search is failing to bring up results for some reason???
Present:...
Past:
Past:
RE: New posts problems
It seems to be related to the Google Links. I'm using Firefox with NoScript which blocks the ads; previously you could minimise the ads, but since the upgrade the button minimise button disappeared. The challenge is to find a way to stop the problem for all and still keep the ads that bring in good revenue.
I think the short term solution is to find a way to reinstate the minimise icon..... I'll research.
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Present:...
Past:
Past:
Any more thoughts or solutions? I see on the other thread you advise "no scripts" what is that?
Present:...
Past:
Past:
No Script - http://noscript.net/
Or another potential option could be to edit your hosts file and add googlesyndication.com in the same line after localhost.
| Ultima Evolution
where would I find my hosts file?
Present:...
Past:
Past:
Warning - What you are doing here is beyond everyday PC usage....
Go to Start
Then Run
Type this %windir%\system32\notepad.exe "C:\WINDOWS\system32\drivers\etc\hosts"
Click OK
You'll get this:
What you are basically telling your PC is that the web server for googlesyndication.com is on your PC, which obviously it is not so it will not load the ads.
Go to Start
Then Run
Click OK
You'll get this:
Change the last line to:# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
Close and Save. If you have your web browser open, you will need to close it (all of them) and re-open. If you are using a proxy (corporate environment) this probably will not work (Download Firefox and install the No Script add-on).127.0.0.1 localhost googlesyndication.com
| Ultima Evolution
- SimonS4MTM
- Top Gear
What are the implications of doing this Phil?
- SimonS4MTM
- Top Gear
So if I am looking on this site from work, I will need to use firefox??????
The implications are minimal, but I offer no warranty.
Firefox offers a better level of protection and will deliver better results in a corporate environment.
| Ultima Evolution
- SimonS4MTM
- Top Gear
Correct me if I am wrong but it seems to me like we are being asked to change our pc settings or use a different web explorer because you cant fix a bug.
Re: RE: New posts problems
behave phil. Firefox 2 has been proven to be no more secure than IE 7. They do update it faster so holes are fixed quicker. It is more usable.PhilT wrote:The implications are minimal, but I offer no warranty.
In a corporate environment protection should never be left to the end user. Proxies, Firewalls, Managed AV services are all employed by admins like yours truly to ensure al the user has to do is get the URL right.
to suggest that a user in a corporate environment should be using firefox is folly. is there a GPO for firefox? can I control what the user can do so that they can't break their app?? No, which is why firefox isnt a corporate standard browser let alone one which can deliver better results.
doesnt sound like a bug, sounds like a conflict between certain settings. either accept the workaround or give the admin time to fix it. remember you don't pay for your membership and admin has a job as well as this site (and probably a family and other hobbies too...)SimonS4MTM wrote:Correct me if I am wrong but it seems to me like we are being asked to change our pc settings or use a different web explorer because you cant fix a bug.
Matt
- SimonS4MTM
- Top Gear
RE: Re: RE: New posts problems
Thanks Matt, comments noted!
i only commented cos i run a smaller dub site and i know how crap i am at updating it
