CAMSHAFT WORN , BUGGER
Hi guys. Well today been a bad day. Just thought i would fit my rocker cover gasket left bank. To my horror i found a very worn exhaust camshaft lobe and tappet worn though. In fact there was no tappet. There has been no warning signs that its gone. not even a rattle or lack of any performance. Hoping have got away with minuim damage. Has anyone come across this before ? Thanks in advance.
RE: CAMSHAFT WORN , BUGGER
Ive seen reports of this before on the 2.7T.
Nogaro S4 Yr2000. MRC remap, K04s, Milltek
There have been a few cases . New set of cams and tappets should see it right.
Unit 20
0151 3366888
0151 3366888
lucky you found it in time
how many miles ?,what oil are you using ?
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
Re: RE: CAMSHAFT WORN , BUGGER
[quote="imolas4uk"]how many miles ?,what oil are you using ?[/quote
81.000 miles. Only had the car 3 months so do not know what oil its had up to me buying it. Done one oil change when i got it and put castrol magntec in. Looks like right hand bank had same problem as its had a new exhaust camshaft already.
RE: Re: RE: CAMSHAFT WORN , BUGGER
does it have good history ie fixed or variable service schedules ?,has the previous owners missed any services ?
Re: RE: Re: RE: CAMSHAFT WORN , BUGGER
Its got good serivce history. On fixed servicing. Has not missed any services. last service was done at 80k.imolas4uk wrote:does it have good history ie fixed or variable service schedules ?,has the previous owners missed any services ?
- Top Gear
RE: Re: RE: Re: RE: CAMSHAFT WORN , BUGGER
Is Magnatec fully synthetic?
well they do do a fully... just looked Blue, most of there range is semi.... http://www.castrol.com/castrol/sectiong ... 71#7106416
Off topic a bit, well not really. Millers is a good oil, but most dont use it over here... not that main stream
Darren
Darren
